Results 1 to 3 of 3
Thread: No audio input!
  1. #1
    In The Zone Chetan1991's Avatar
    Jan 2007
    Shimla
    Question No audio input!
    Plz help! I checked "Output digital and analog" under S/PDIF-Out In AC97 Audio Conf. program to record music playing on comp. itself.Since then I am unable to record audio from my mic.
  2. #2
    Still Shining! Lucky_star's Avatar
    Nov 2006
    Up 'n' above
    Default Re: No audio input!
    S/PDIF-Out In AC97 has nothing to do with your Sound recording from the Computer. For sound card recording use any audio editor and while recording, select the source as StereoMix.
    For recording from mic, select the source as Microphone.Double click on the volume icon in the system tray. From properties select Microphone. Now uncheck it while recording.
    Nokia N86 8MP
  3. #3
    Feb 2007
    Lightbulb Re: No audio input!
    to select any input other than "stereo mix" or "spdif" you have to unselect "output digital and analog" option on spdif settings page. don't ask me why. "output digital only" will allow you to select mic input while keeping s/pdif digital sound output.
    Quote Originally Posted by Chetan1991
  1. audio output and microphone input low
    By anonymous in forum Hardware Q&A
    Last Post: 14-06-2012, 03:15 PM
  2. My soundcard does not take input well.
    By stevenVFX in forum Audio
    Last Post: 08-11-2011, 08:32 PM
  3. Replies: 6
    Last Post: 13-07-2011, 09:28 PM
  4. Replies: 2
    Last Post: 23-03-2011, 12:05 PM
  5. Where to ACTIVATE audio input in Win Vista?
    By nil_3 in forum Software Q&A
    Last Post: 24-06-2008, 02:50 AM
