Old 25-01-2007, 10:07 AM   #1 (permalink)
Default Window Defender Causing Problem
Hello Everyone!!!
Friends I am not able to send mail through Postmaster(mailing software) after installation of Windows Defender.
How can i configure Windows Defender for sending and receiving mail on a mail server.
I am using Postmaster for sending and receiving mail in a LAN Enviorment. SMTP and POP are the protocol used for this purpose.
I didnot find any option to set it so pls advise me.
thanks
sainit is offline
Old 25-01-2007, 12:15 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Window Defender Causing Problem
Are you sure it is due to Windows Defender? Try shutting down its real-time scanner?
Kiran Kumar R
Kiran.dks is offline
Old 25-01-2007, 03:12 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
^ i second that. cudnt be the windefndr. something else. check ur fw settings.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-01-2007, 05:42 PM   #4 (permalink)
anand This is only due to Windows Defender because earlier all mails were going. As I installed defender i got this problem of mail blocking.
As i uninstall the Windows Defender again mail starting to going outside.
So pls tell me Exact path of configuration sothat i can configure it.
I didnot find any such options.
thanks
sainit is offline
Old 25-01-2007, 06:58 PM   #5 (permalink)
anandk's Avatar
!? c if something here helps u http://www.kbalertz.com/kb_927367.aspx
Microsoft® MVP
anandk is offline
Old 26-01-2007, 08:23 AM   #6 (permalink)
Kiran.dks's Avatar
Here is a snap-shot of the settings...
Maintain this and check out whether it solved your problem.
Kiran Kumar R
