Old 25-01-2007, 03:39 AM   #1 (permalink)
tintin100's Avatar
Unhappy DVD audio stream lag
It is an repost, because the previous post had no reply.
I have an vob file (also have the mpeg file), which playes the audio stream 4-5 seconds later. I want to correct the time lag and rebuild the file, and then burn to dvd again. The error happened, when my friend burned some vob files to a dvd using nero vision express. (We dont have the original dvd containing the original files.)
Which software i need?
How to correct it?
PLEASE someone help, (because none replied to the previous thread )
Just Came here to see what is happening on Digit Forum...
tintin100 is offline
Old 25-01-2007, 02:59 PM   #2 (permalink)
Arrow Re: DVD audio stream lag
I think Cucusoft Mpeg/Mov/RMVB/DivX/AVI to DVD/VCD/SVCD Converter Pro can help you , you can find it at http://www.oursdownload.com/convert-...EG1-MPEG2.html
hope that can help you , good luke !
maryli is offline
