Old 24-01-2007, 07:15 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Cool Samsung's DVD Combo unable to read NFS MW Disc...
hey frenz...
i m having an original DVD of NFS MW .....now when i install MW on my pc thru my Samsung DVD writer , it experiences no prbs.....but when i try to install it on my brother's pc having a samsung Combo Drive ...the drive is unable to read the disc and the system hangs....
ne ideas wat the prb can be ??
ne help wud be appreciated ....Thanking u ppl in anticipation....
BlackBerry7100g..
Username Changed - BlackBerry7100g To BBThumbHealer !
BBThumbHealer is offline
Old 24-01-2007, 07:23 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Samsung's DVD Combo unable to read NFS MW Disc...
same sh1t prolem happened with me. all the games i bought (both orig & p-rated) ran fine on my cousins PC & laptop, but never on my PC
the other CD's, DVD's worked fine.
only the game disk, sometime showed CRC error, & sometimes not detected.
the Solution-> Clean the Drive. i used a CD cleaner, then used Vaccum cleaner Blower, & again the Lens cleaner
the CD's were also cleaned (i used Colin Liquid Cleanser).
after this, evry thing Worked FINE
__
s18000rpm is offline
Old 24-01-2007, 07:24 PM   #3 (permalink)
hey ... but my brother has purchased his combo drive just 1 week back...
Old 24-01-2007, 07:34 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
does this problem occur with other disks too???
__
Old 24-01-2007, 08:52 PM   #5 (permalink)
Try me
shantanu's Avatar
I think it can be amanufacture problem get your drive replaced if you bought it some time back, and also some leads problem can be there
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 24-01-2007, 11:00 PM   #6 (permalink)
but other discs are not encountering prbs...
Old 24-01-2007, 11:07 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
do what i told you, clean the disk, & blo clean the Drive Interior & see whether the CD runs, coz my PC was just a month old when these probs. occured.
maybe you bro. used some dirty CDs of movie
__
Old 24-01-2007, 11:17 PM   #8 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Get it replaced n see if problem persists
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is online now
Old 25-01-2007, 05:26 PM   #9 (permalink)
the CD's were scratch-free......
