Old 24-01-2007, 02:51 PM   #1 (permalink)
Cool G5's Avatar
Question CD/DVD Not getting read
I recently reinstalled Windows XP on my pc.But when i insert some cd's & Dvd's in the explorer it shows cd/Dvd has been inserted.But when i Double click the icon it shows that "The disk migh be corrupted or using a unknown format".I checked this disk on my friend's pc & it was working fine.This problem not used to happen before reinstall.
Cool G5 is offline
Old 24-01-2007, 04:32 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: CD/DVD Not getting read
If the prob is with many CDs/DVDs then check ur CD-ROM on ur friends PC woth same CDs/DVDs.
Minds are like Parachutes They work best when open
n2casey is offline
Old 24-01-2007, 05:34 PM   #3 (permalink)
!FREEWARES!
Akshay's Avatar
Hope u hav installed all d drivers properly... As dis prb is occuring aftr installation, u must not hav installd XP properly. U can try reinstallation of d drivers for ur drive. If dat doesnt wrk, try reinstalling XP. Meanwhile if its poss., try wht casey says...
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Akshay is offline
