Old 18-01-2007, 08:51 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Arrow Taskbar Repair Tool Plus!
so many threads on taskbar issues. a good tut somewhere too !
but for those lazy ones like me, heres an xclnt ready-to-use taskbar repair tool from kellys-korner.
This application allows you to Repair and Customize the Quick Launch, Taskbar and Notification Area in Windows XP. These are the options available via this tool.
Taskbar
Taskbar is Missing
Lock Taskbar Greyed Out
Minimized Programs Missing
Stuck in Classic View *
Reduce Size of Buttons
Restore to XP Default * (clickable)
Toolbars Greyed Out or Missing
Remove Specific Toolbars or Remove All *
Remove System Icons from Desktop Toolbar *
Disable Taskbar Context Menus
Remove Taskbar and Start Menu from the Control Panel
Disable Right Click/Properties
Lock Size and Position of the Taskbar
Remove Open, Explore and Find from Start Button Right Click *
Remove Open All, Explore All Users from the Start Button Right Click *
Hide or Show the Taskbar
Repair Taskbar Icon Views
Hide or Show the Start Button
Restore Taskbar to Default Position *
Enable or Disable Taskbar Grouping (Removes the options from Properties)
Repair, Disable or Enable the Task Manager
Notification Area
Hide or Show All Listed Icons
Hide or Show All Inactive Icons
Remove Past Items
Show Missing Icons
Restore/Remove the Clock
Disable Balloon Tips
Remove the Notification Area
Remove Selective Icons (also from Msconfig/Registry) *
Disable Low Disk Space Warning Message and Icon
Quick Launch
Can't Create Toolbar Error Message (Create)
Can't Create Toolbar Error Message (Repair) This one corrects the current issue that spyware cleaners break.
Restore Show Desktop Icon
Remove the Quick Launch Area *
Save Quick Launch Sort Order
Auto Add Specific Links to Quick Launch *
Set Quick Launch as Default for any new user added
for details/download click http://www.kellys-korner-xp.com/taskbarplus!.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-01-2007, 08:59 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Taskbar Repair Tool Plus!
thanks nice tool
Tech Geek is offline
Old 18-01-2007, 09:00 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
thanks.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 28-01-2007, 04:39 PM   #4 (permalink)
ketanbodas's Avatar
Thanks. Will download and keep it Just in case
Life is like a game - Enjoy playing it.
ketanbodas is offline
Old 29-01-2007, 05:15 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
tool is useFOOL indeed ...........
ax3 is offline
