Re: help help help cant c pen drive icon
friend if you are not able to get cmos plz try to get cmos from another keys like tab,f1 etc if not able then tell here if there is setting problem or password protect you can able to crack it by open your cpu s case and disconnect cmos battery then after few minutes insert it properly and then try again
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
