Cause: Trojan or Virus. Unsure. Most likely contracted from an infected webpage/website.
I've never experienced anything like this before. There was no BSOD but this is so severe, I had to turn to the power off and am too scared to switch on computer.
Effect:
1. web browser (IE, version ?) couldn't function, except load homepage (which I have always set to Google). Error message: Microsoft Visual C++ Runtime Library Runtime error C:\program files\internet explorer\IEXPLORER.EXE R6025 -pure virtual function call
2.I tried to open Ewido. Error message: Not enough quota is available to process this command.
3.Tried to open HijackThis but could not access hard-drive.Error message: Not enough quota is available to process this command.
4.Tried again to open Ewido via shortcut. Error message: This no longer exists. It might have been renamed, moved or deleted. Would you like to remove from list? (I pressed No)
5.Tried again to open Ewido. Error message: Application failed to initialize properly (0xc000012d). Click to terminate application.
6.Tried to open Ewido again. Error message: SecuritySuite.exe -Bad Image The application or DLL C:\windows\system32\PSAPI.DLL is not a valid Windows image. Please check this against your installation diskette.
7.Opened Spybot, forced to download updates before scanning. Then couldn't find anything after scanning for only few seconds (unusual- scans always take over 5mins). Error message: C:\windows\system32\SHDOCVW.DLL is not a windows image. Check this against your diskette.
8.Pressed scan button in Spybot to scan again but no response. Then when I tried to close it, Spybot started scanning (delayed response?). I kept trying to close Spybot because I thought it wouldn't work anyway. Then I tried to shut down computer but no response so I turned the power off. Computer is still off.
Thank you very much for reading this post. I'm sorry it was long, but since I don't know alot I put all the information I had. Help would be deeply appreciated.
Re: Worse than BSOD. Trojan or Virus. Urgent Help!!
the dlls have unregistered themselves it seems. Could be a virus, but i don't think so, it seems more like some application removed which un-registered these while uninstalling
1st method -> Go to safe mode, put the Windows XP CD in the drive & start->run->sfc /scannow
2nd method-> use some antivirus.
Don't worry your computer is all right, u can open it
