Old 08-01-2007, 01:47 AM   #1 (permalink)
An Esoteric Geek
sridatta's Avatar
Default error opening my hard drive partition
hello frenz
I am getting the following error when i doubleclick on any of my hard drive partitions.
"cannot find copy.exe. Make sure you have typed the name correctly and then try again..........."
please help
sridatta is offline
Old 08-01-2007, 02:05 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: error opening my hard drive partition
Search for autorun.inf file in the root of all drives (like c:\autorun.inf, d:\autorun.inf, etc.). It should be HIDDEN
If u find it, delete the file
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 08-01-2007, 02:10 AM   #3 (permalink)
Arsenal_Gunners's Avatar
A hard way is
start >> run >> regedit
backup ur regedit by clicking file>export in regedit
Then Open this key with regedit:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\MountP oints2\
delete anything will look like this ---> (eg. {6f745f47-6814-11db-940b-00138f7c0a44} )
u will find it under the mountpoints
leave the drivers letters only, in the list
BE SURE TO SAVE THE REGISTRY FIRST.
Plz rep if works
Arsenal_Gunners is offline
Old 09-01-2007, 07:55 PM   #4 (permalink)
An Esoteric Geek
sridatta's Avatar
@vimal - I could not find any such key...
@vishal - ye.. i deleted them and after restart, the problem is solved..
thanks guyz...
sridatta is offline
Old 09-01-2007, 10:57 PM   #5 (permalink)
It was just an example.Its ok if your problem has been solved
Old 26-01-2007, 01:59 PM   #6 (permalink)
i have the same problem, but after restart it reappears...
sushantvirdi is offline
Old 08-02-2007, 02:40 PM   #7 (permalink)
Please help, the problem is still there..
Old 08-02-2007, 03:20 PM   #8 (permalink)
try these ways http://forums.techguy.org/security/4...find-copy.html
Also search google for "can't find copy.exe" there are a lot of solutions.
Old 08-02-2007, 04:05 PM   #9 (permalink)
nishant_nms's Avatar
@sushantvirdi scan ur system for viruses and spywares
nishant_nms is offline
Old 08-02-2007, 04:20 PM   #10 (permalink)
I found a removal tool on kaspersky website and it solved my problem..
Thanks anyways...
Old 17-06-2007, 12:53 PM   #11 (permalink)
Resident Fanatic
Manshahia's Avatar
My system was also infected by the same trojan and Kaspersky Detected that..
I hav also deleted the files autorun.inf from all the drives..
but the options Autoplay and Search are still there..
Is there anyway to remove them??
I cant open my drive by rite clicking
Ok i hav got the answer..
Software's name is TrueSword 4..
one can download this software for automatic editing of the registry so that options like autoplay and search can b removed and one can open the drive by double clicking.
Manshahia is offline
Old 11-10-2007, 03:36 AM   #12 (permalink)
gsmsikar's Avatar
is there any free tool to remove or clear the copy.exe message ?
gsmsikar is offline
