Old 01-01-2007, 11:49 AM   #1 (permalink)
Default incorrect MS-DOS function??
whenever i try to copy n e film to my hard disk from the cd then the cd gets copy to certain extent the an error message appears saying "window cannot copy:incorrect MS-DOS function" and nothing gets copied
can n e tell me what is this problem??????????
thankx in advance!!!!!!!
rounit is offline
Old 01-01-2007, 11:55 AM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: incorrect MS-DOS function??
It means that the movie is corrupt on that cd.
Possibly it was a bad cd or the burner is playing up.
Third Eye is offline
Old 01-01-2007, 12:12 PM   #3 (permalink)
Super Hero - Super Powers
n2casey's Avatar
No, there isn't any prob with CD. It seems that U r using LG CD-ROM.
Well for any CD-ROM the best solution for such prob is to use Alcohol 120% to make an image of that CD (select Skip read errors during this process). After that, just mount that image on any Virtual Drive & enjoy......
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 11-01-2007, 06:54 PM   #4 (permalink)
Security Exp
47shailesh's Avatar
creating image is the best solution no tension i 100% agree with n2casey
We Love Once, And When We do We do it Well
47shailesh is offline
Old 11-01-2007, 10:33 PM   #5 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Smile Re: incorrect MS-DOS function??
quite true , me too have LG combo and has faced such problems many times, now I use only CDs in good condition or make images .
n00b forever...
~Phenom~ is offline
Old 11-01-2007, 11:07 PM   #6 (permalink)
String Phreak
mediator's Avatar
I too agree with @n2casey! Its a fast method tooo!
mediator is offline
Old 12-01-2007, 12:25 AM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
You can use Nero to create an image, and later use Nero image Drive to load that image.
Nokia N86 8MP
Lucky_star is offline
Old 12-01-2007, 11:27 AM   #8 (permalink)
n2casey's Avatar
Wink Re: incorrect MS-DOS function??
But Nero doesn't provide any option to skip read errors. Alcohol provides u that option too which is much helpful when copying scratched CDs. IsoBuster & similar s/w r also effective in such cases.
n2casey is offline
Old 12-01-2007, 01:43 PM   #9 (permalink)
Security Exp
47shailesh's Avatar
Dude Nero automatically skips read error and create a image of what it can read properly
Old 12-01-2007, 11:52 PM   #10 (permalink)
Still Shining!
Lucky_star's Avatar
Yeah, Nero does that automatically
Nokia N86 8MP
