Old 23-12-2006, 05:57 PM   #1 (permalink)
vipinkumarsolanki's Avatar
Question Dial Up Speed
Hi friends
how can i get maximum speed from my dial up connection?
vipinkumarsolanki is offline
Old 23-12-2006, 08:09 PM   #2 (permalink)
Default Re: Dial Up Speed
Just simple upgrade your dial up modem to Broadband.
boosters is offline
Old 23-12-2006, 08:35 PM   #3 (permalink)
nishant_nms's Avatar
time for an upgrade
nishant_nms is offline
Old 23-12-2006, 11:14 PM   #4 (permalink)
You might find some softwares on download.com that claim to boost the network connectivity by altering some registry settings based on type of connection like broadband / dialup etc!
Instead of using dial up, go for broadband, eventually it may turn out to be a cheaper & better option, especially if your dial-up was not stable. i.e. not getting good speed, modem hang-ups & disconnects etc.
patkim is offline
Old 23-12-2006, 11:39 PM   #5 (permalink)
rajaryan_13's Avatar
I second on patkim
go for Data1 h500 plan, it should suffice all ur needs
rajaryan_13 is offline
Old 23-12-2006, 11:48 PM   #6 (permalink)
TheSaint
NucleusKore's Avatar
Go for AirTel 999UL if you have in your area
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 24-12-2006, 12:12 AM   #7 (permalink)
webgenius's Avatar
Download netspeed & PC accelerator
webgenius is offline
Old 24-12-2006, 03:19 AM   #8 (permalink)
Salieri Family
hard_rock's Avatar
Location: Somewhere in Internet.......Have dynamic IP address
Do some tweaks using tweak xp pro/system mechanic pro. Use Opera for browsing as it has good cache management system and speed... You can just only optimise what you get and cant imagine to get 10KBps-15KBps on 56kbps modem connection...
A person who wants everything in his life... May end up with nothing at all
-Tommy[Mafia]
hard_rock is offline
