| Forum |
#1 (permalink) |
When i upgraded my IE 6 to IE 7, the installation worked fine. After restarting the windows, I recieved an error ' windows explorer encountered an error and needs to close'' After clicking the ''dont send'' button, I cant see my taskbar and desktop icons. even right click on desktop does'nt work. My desktop stands still.Its only after pressing ctrl+alt+del, i am able to shut down windows using task manager. PLZ HELP ME TO SOLVE THIS IE7 PROBLEM.THANKS |
#2 (permalink) |
Distinguished Member
rt click my comp > properties > advanced > error reporting > disable error reporting
also configure ur xp to "restar desktop and taskbar automatically after errors" open regedit and navigate to : HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\ CurrentVersion\Winlogon Look at AutoRestartShell (a REG_DWORD) in the right hand pane. If it is 0 (do not restart), set it to 1(automatically restart). with TuneUp Utilities u can do both very easily
> www.TheWindowsClub.com < = www.WinVistaClub.com = Microsoft® MVP |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
