| Forum |
#1 (permalink) |
i m using AMD Semptron 2800+. well,unfortunately my pendrive got virus frm a computer (automaticaly duplicating folders).and whn i used n my above said pc,it too got effected. nw, i triedvto install AVGBAnti Virus.whn i m opening avg's folder,to install,it automatically gets closed,and refreshing. whn i tried to view all files in tools-folder options, the same thing happns. hw can install anti virus? pls help me it is my official pc too. w iting to get solved wt loves shinu |
#2 (permalink) |
Microsoft MVP
Try to install the anti-virus in Safe mode!
Also download "HijackThis" from www.hijackthis.de and then run it and post the Logfile contents here. |
#3 (permalink) |
Most of the virus don't allow antivirus softwares to get installed on your system once they invade the system.
In such cases Virus removal tool is more efficient. >Download the above cleaner >Log on to Windows in safe mode >Run the cleaner The cleaner will disable the Virus and then remove it. >After the clean-up operation, install Antivirus software >Update the definitions and perform a scan >Install Ccleaner and scan the registry.
Kiran Kumar R |
#5 (permalink) |
>Start
>Run >Type msconfig and click 'OK' >You will get a 'System Configuration Utility' menu >Click 'BOOT.INI' tab >In 'Boot options', check '/SAFEBOOT' and click OK >Restart computer
Kiran Kumar R |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
