Old 08-01-2005, 02:36 AM   #1 (permalink)
Default Video spitting software so that the parts are playable?
HI,
Is there any software which can split a video file into two or more parts such that both the parts are still playable.
If yes can you please tell me from where can i get it.
Thanks
rachitar is offline
Old 08-01-2005, 08:12 AM   #2 (permalink)
hey S'up;
There are 100's of such software ; go to www.download.com
and in its search type "video splitter " and vola you will have a list of many good video splitters to download. Best of luck on your Banana splits.
Cheers
Peace V
bravefart is offline
Old 08-01-2005, 09:34 AM   #3 (permalink)
swatkat's Avatar
There's a FREE VCD cutter called VCD Clipper,works only for .dat files.
Download here:-
http://www.canalsw.com/product.php%5...Dcanalsoftware
There's another good one called AVI/MPEG/ASF/WMV Splitter,also splits VCD files,Download trial here:-
http://www.boilsoft.com/videosplitter/
Another good one is VCD Cutter,download trial here:-
http://www.downseek.com/download/21277.asp
But,for VCDs,VCD Clipper is more than enough,best of all, it's FREE.
http://swatrant.blogspot.com/
swatkat is offline
Old 08-01-2005, 03:10 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. I posted it here .. :
Contribution to tips and tricks Jan 2005 ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 14-06-2005, 02:03 PM   #5 (permalink)
Maverick340's Avatar
I wanted to take out frames(.bmp,*.jpg) from a .mpg or .avi or .dat file..
I tried using VCD cutter but it gave problems...
Can u seggest me another s/w?The problem it gives it an unexpected error...it happens when i try to click the "extract frame" button
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 14-06-2005, 09:20 PM   #6 (permalink)
q3_abhi's Avatar
VCD cutter is the best n easy 2 use. U can play the splitted parts.U can also cut ur audio files n play them
q3_abhi is offline
Old 14-06-2005, 10:20 PM   #7 (permalink)
i'd reommend vcd cutter too, any dummy can use it, and it has decent features
cyberia.in is offline
Old 15-06-2005, 12:59 PM   #8 (permalink)
tuxfan's Avatar
Do any of these software work on quicktime movies (.mov files)? My Nikon Coolpix makes .mov files and at times I have to live with useless portions as well
tuxfan is offline
Old 15-06-2005, 03:09 PM   #9 (permalink)
tuxfan....ur best bet would be to conver it to a avi file and then do your editing. mov to avi conversion can be done using AimOne.
Also virtualdub is enough for all your video editing needs and its free too. Excellent software.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 16-06-2005, 12:31 PM   #10 (permalink)
tuxfan's Avatar
Ok. Thanks.
tuxfan is offline
