Old 13-12-2006, 12:04 PM   #1 (permalink)
Default Booting Problem
I HAVE A P4 INTEL WITH XP SP2 INSTALLED .
WHEN I GO TO START MY SYSTEM IT START SMOOTHELY BUT AFTER WINDOWS SCREENING IT DONT BOOTING FURTHER , IT SAYS AN ERROR POWER............. I MEAN I CANNOT SEE THE WINDOWS.
BUT IN SAFE MODE IT RUN OK.
suraj is offline
Old 13-12-2006, 12:41 PM   #2 (permalink)
::vicky::'s Avatar
Default Re: Booting Problem
reinstall windows
HEY! WHO THE HECK STOLE MY SIGNATURE!!!
::vicky:: is offline
Old 13-12-2006, 03:02 PM   #3 (permalink)
I Always Prefer 1080p
techtronic's Avatar
^^ Thats the final solution
If you are able to go to Safe Mode try editing boot.ini file with /sos added instead of /fastdetect
/sos will tell you which drivers are faulty and if you can rectify or copy those drivers from XP CD,there would be no problems
And next time please dont use CAPS
Source : http://www.winguides.com/registry/display.php/1268/
techtronic is offline
Old 13-12-2006, 03:22 PM   #4 (permalink)
i found some brontok.........virus.:-P
suraj is offline
Old 13-12-2006, 03:35 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
do a online scan at bitdefender.com
ravi_9793 is offline
Old 13-12-2006, 04:54 PM   #6 (permalink)
thanks
suraj is offline
Old 14-12-2006, 10:56 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
thanks
welcome sir......
Old 16-12-2006, 02:52 PM   #8 (permalink)
welcome sir......
A very happy christamas and happy new year......
suraj is offline
Old 16-12-2006, 03:07 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
same to you dude...
Old 17-12-2006, 02:07 AM   #10 (permalink)
anilmail17's Avatar
suraj i adviced u that ur machine is infected with brontok when i posted a reply for ur folder option not availabe thread and i have also given u some links to removing tools but u not belived me
anilmail17 is offline
Old 18-12-2006, 12:23 PM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try a FULL system scan 4 virus .......... ONLINE .......
ax3 is offline
Old 02-01-2007, 04:29 PM   #12 (permalink)
U know i did the same thing according u , but atlast i found true
thanks yaar
__________
thanks
__________
thanks yaar
suraj is offline
