Old 11-12-2006, 06:36 PM   #1 (permalink)
Team Digit
r4gs's Avatar
Default System Restore
I would like to know if there is a way to save specific system restore points separately, say on a cd or dvd, in such a way that it is still usable.
r4gs is offline
Old 11-12-2006, 07:26 PM   #2 (permalink)
weary_wanderer's Avatar
Lightbulb Re: System Restore
Under the folder "System Volume Information\_restore{GUID}", there are subfolders called RPx where x is a number, the highest number is the latest Restore Point.
In the RPx folder, there is a subfolder called snapshot, which contains all the registry hives.
In essence its these snapshot folders that you'll have to save separately
If your machine ever gets into a no-boot situation you can follow these steps to manually perform the system restore:
Step 1:
Boot with the windows XP CD
At "Welcome to setup screen" Press R
Select the appropriate path for windows and press enter
If it asks you for the administrator password, type the administrator password and
press enter or just hit enter
We will now see the Prompt c:\windows>
Step 2:
cd system32\config
ren system system.old
ren software software.old
ren SAM SAM.old
ren security security.old
ren default default.old
cd
Type cd system~1\_resto~1 and press Enter
If you get "access denied" (Error) then
Restart the computer by type Exit and get back to recovery console
type cd \ and it will display C:\>
type cd system~1\_resto~1 and press Enter
Step 3:
Type dir
It will list you restore points
(e.g. RP1, RP2, RP3, RP4, etc...)
Select the one from the list except the last one
Say RP4
· type cd RP3 (or RP2 or RP1 or RPn) and enter
· type cd snapshot and enter
· type copy _registry_user_.default c:\windows\system32\config\default and enter
· type copy _registry_machine_security c:\windows\system32\config\security and enter
· type copy _registry_machine_software c:\windows\system32\config\software and enter
· type copy _registry_machine_system c:\windows\system32\config\system and enter
· type copy _registry_machine_sam c:\windows\system32\config\sam and enter
· type exit and enter
The computer restarts and the system will be successfully restored
Lee...
___________________
Cogito, Ergo Sum...
weary_wanderer is offline
Old 11-12-2006, 07:27 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
Default Re: System Restore
u can try freeware Spl Ltd Offer : Get Acronis True Image for Free !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 12-12-2006, 07:54 AM   #4 (permalink)
nishant_nms's Avatar
Use Acronis True Image it is great
nishant_nms is offline
Old 12-12-2006, 10:02 AM   #5 (permalink)
I Always Prefer 1080p
techtronic's Avatar
I have been an Acronis User for 9 Months now
It rocks
techtronic is offline
Old 12-12-2006, 10:21 AM   #6 (permalink)
Team Digit
r4gs's Avatar
Thanks a lot everyone
r4gs is offline
