Old 06-08-2004, 01:52 PM   #1 (permalink)
Default Burn a 800MB (90min) cd using Nero
Hi
I bought a couple of 800MB cd-r 's from a shop. This is the first time i am trying to burn a 800MB capacity cd. Problem is Nero doesn't seem to support the media. My writer is a LG GLC-8525B with a maximum of 52x writing speed. Nero version is 6.3.0.2.
The media is branded as Amkette 24x 90 min (800MB)
What should i do? Any clues?
sailendra is offline
Old 06-08-2004, 01:57 PM   #2 (permalink)
well as far as i know u have to enable overburn in ur software
it wont detect ur cd being 90 min .. u just have to select overburn .. and put in 90 min/ 800 mb of data in ..
there was a small discussion on this earlier
wait for i_w_m or JAK to answer .. i think one of them explained the whole thing
No Mercy, No Limits.
theraven is offline
Old 06-08-2004, 02:25 PM   #3 (permalink)
thanks raven
I already tried that option. After I click burn, the cd is ejected with the message:
There is not enough space to burn this compilation onto this disc. Please insert another disc that provides mor space. :roll:
Old 06-08-2004, 06:00 PM   #4 (permalink)
well ive never overburnt so im sorry
still will try to think on it
once my friend bought 90min cds .. the instructions were on the pack
well i guess u didnt get that
again ... try searching the forum ... or wait for jak to reply
sorry again
theraven is offline
Old 06-08-2004, 06:48 PM   #5 (permalink)
Here's the thread raven is probably referring to:
http://www.thinkdigit.com/forum/viewtopic.php?t=3792
LOL ! Me and JAK had a big argument in that thread ..........lol.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 06-08-2004, 07:55 PM   #6 (permalink)
You can change the default cd storage limit from File - Preferences - General by changing the markers' limits to 80 miniutes and then enebling overburning in the expert features.
jnpandya is offline
Old 06-08-2004, 09:04 PM   #7 (permalink)
JAK
What the Heck !
JAK's Avatar
Originally Posted by sailendra
thanks raven
Hmmm...
Select "No multi Session" and Burn with "DAO"mode(Disk at Once)....
and ya enable overburnin first like
Theraven mentioned
u cannot over burn mutisession disks and/or use any other burnin mode(SAO or TAO) for overburnin.....
EDIT: Replaced Check --> Select
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
Old 06-08-2004, 09:41 PM   #8 (permalink)
yup thats the one
that just moves the pointer. . has nuthin to do with enablin overburn or increasing capacity u can write on the cd
atleast thats what i had noticed
theraven is offline
Old 06-08-2004, 09:57 PM   #9 (permalink)
Thanks guys,
I just checked these cds at a friends place. He has an ASUS writer. Its the same story there. He was using different software to burn cds. Still it shows only 69 minutes 57 seconds as the capacity. I bought these cds for 11 rs. each. Guess I will just use them as regular cd-rs. :roll:
@raven,
Dont feel sorry about it. The main thing is you tried to help. Thats what matters
Old 06-08-2004, 10:05 PM   #10 (permalink)
JAK
What the Heck !
JAK's Avatar
Thanks guys,
@raven,
Did u do as i had suggested.....????
LG Burners support Overburning so do Asus burners.. Its all with the type of Burnin Proggy used..for eg. Nero supports Over Burnin while Easy CD Creator doesnt( dunno abt the latest version)
If u follow what I hav suggested above ..U will be able to easily OverBurn the disk usin NERO....
JAK is offline
Old 06-08-2004, 10:52 PM   #11 (permalink)
JAK,
Yes, I did like u said. In fact I was using DAO (Disc at Once) mode to burn the cd. I even tried changing the Overburning option under preferences. That makes no difference. The cd is ejected and Nero asks for another CD with adequate space.
Old 06-08-2004, 11:02 PM   #12 (permalink)
JAK
What the Heck !
JAK's Avatar
JAK,
Donot select multisession disk...this is important....
Select
"No Multisession"
Which version of nero r u usin....
JAK is offline
Old 06-08-2004, 11:25 PM   #13 (permalink)
Yup, I selected no Multisession. Nero version is 6.3.0.2 (see my first post). Same result.
Old 07-08-2004, 04:40 AM   #14 (permalink)
It also depends on the media. Not all CD-Rs will support overburning. Try it out with good brands like Moser Baer.
U think U know better...???
Naga is offline
Old 07-08-2004, 11:35 AM   #15 (permalink)
yup problem may be with the media
what brand did u say -amkette? amkette isnt a gr8 brand for cd-r's either
i've had bad experiences
PIII 550 MHz 128 MB RAM GeForce 2 MX 400
.:pEaCe:.
Join this cool forum!
www.tech-station.net
Loki87 is offline
Old 07-08-2004, 01:45 PM   #16 (permalink)
thanks,
I will keep that in mind next time i get to buy cds
Old 07-08-2004, 01:48 PM   #17 (permalink)
JAK
What the Heck !
JAK's Avatar
Na na ...U can overBurn with any CDR...the question is ...how much u can over-burn. Different media's have different lengths of the lead out area (90 sec is mandatory)
so u can always overburn in the lead out area..its just a question of how much
ofcourse u need a burner that supports O/B
Oh sorry missed readin it in a hurry...
Well what can I say....
what u have is a 52X newer model which definitely supports 90MIN CDR's..
I think u r doin something wrong...or maybe Nero has screwed up itself.......
One Last try...STEP By STEP Procedure Comin up....
JAK is offline
Old 07-08-2004, 01:52 PM   #18 (permalink)
JAK
What the Heck !
JAK's Avatar
Ok Here it is ...
STEP 1:
Fire up Nero and when the wizard appears select no multisession
STEP 2:
Go to File--->Preferences ---> Expert Features: and set it up as in the image..
STEP 3:
Add all ur files, change CD label etc and Select burn compilation..and select DAO burn mode as shown here..
STEP 4:
upon selecting burn Nero will give the following prompt..just click "Write Overburn Disk"
as u can see i am tryin to fit 798MB of data in a 656MB CDRW so no probs here dude...
"AB SAALA NERO KYA ....USKA BAAP BHI OVERBURN KAREGA"
JAK is offline
Old 07-08-2004, 02:10 PM   #19 (permalink)
Boy, You are persistent. Thanks for taking the trouble to put in all the screen shots
I will try it once more and let u know the results.
p.s: That a nice skin for your OS. Could you tell me where you got it?
Old 07-08-2004, 02:28 PM   #20 (permalink)
It WORKS! It WORKS! I followed your procedure exactly, and it works. Was able to burn a 795MB cd succesfully. THank you Thank You!
Never imagined it could work. Thanks a million JAK
Old 07-08-2004, 03:49 PM   #21 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
LOL
well thanks man JAK u the man
even i was trying to find a good ol solution for Gf she was tryin it but cudnt do it nor cud i
now THANKS TO YOU
i can boast a bit
thank again
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 07-08-2004, 10:13 PM   #22 (permalink)
JAK tell u what post this as guide in a new post! That will probably save ppl a lot of trouble and u and me a lot of arguing (kidding on that mate).
Old 07-08-2004, 10:50 PM   #23 (permalink)
JAK
What the Heck !
JAK's Avatar
lol...m8...I will..I will m8....lol
JAK is offline
Old 11-01-2005, 05:03 PM   #24 (permalink)
thks alot......................................this guide is definately damn helpfull................iska bina mera 800mb ka disc ka kya hota???????..........................thks jak for the guide........................
magnet is offline
Old 11-01-2005, 06:13 PM   #25 (permalink)
bad news frm my side...............it failed at end...2 disc r waste...............first i thght....i used a higher speed to write(40x)...where as the cds were only 32x compatible....in another disc i took care of all thing...still it failed........................disc is of sprint company...........................
800mb specified......i using nero 6.3.0.x...sony 52-32-52 writer........
i m getting write error...also on checking the disc frm bak its writted only ard 4% i guess......system hangs with both the disc.....................
whts the prob with the disc any idea....????
also i writed 685 mb file on the disc on 3rd one....it got writed well(at 8x speed)...............also i would lik to know the process u told works well with the rw also or wht?????
magnet is offline
Old 11-01-2005, 08:50 PM   #26 (permalink)
 Macboy
goobimama's Avatar
Default try this
Maybe you should try heating the CD on a low flame, then, when it is piping hot, insert it in the drive and try to just shake the computer violently (very violently). and then try overburning!
Actually, I had the same Amkette CDs which said they were 800 MB, but they are worthless garbage. to burn on an 800 MB cd, you have to overburn with disk at once, and no multisession. I have tried it with other CDs and it worked. Amkette sucks.
Milind
I'm like a bird... :)
goobimama is offline
Old 13-01-2005, 02:42 AM   #27 (permalink)
SABER RIDER
maverickrohan's Avatar
Yo goobi,
i cud compute the 2nd para of ur post......but dudehhhh 8) Wht did u intend to say with the first one.....
Well......Im surprised, a problem with simple solution is turning out to be such a long post.....Poor ol JAK had to explain all he wrote(IN THE FIRST PLACE) with screenshots ......guess ppl compute things better with illustrations.
Hey n all those ppl, trying to overburn after reading this post.....
:::CAUTION:::
Overburning screws up ur drive and majorly shortens its life, I have lost my Samsung 224B which i had bought for Rs.6150/- to my Overburning adventures(which i have been doin from past 3 yrs)............
It screws up the lens assembly & even Nero cautions u against using it.....
magnet:
u havent mentioned whether u were using 700MB or 800MB cds OR the 800MB u specified was the amt of data u were trying to burn...
Anyways, The max i have overburnt on a 700MB Cd was 724MB of mp3s on colored "Neon Melody 24x" And it actually took 12 minutes, outta which 8 minutes was for writhing the last 1%, during which my drive made all sorts of noises.....
If the CD is truly 800MB, writing 800MB shudnt be a prob, if ur writer is cable of writing 800MB................
P.S.:: Just for info, i remember readin this article a couple of yrs back, Sanyo had invented a Writer that cud burn 1400MB on ordy 700MB disks, but the limitation was, those disks cud only be read by those writers...now thats understood :roll:
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 13-01-2005, 11:07 AM   #28 (permalink)
ya i have cds of 800mb and have sony crx230 writer....i dont know whether its capable of burning 800mb........btw....i will b using those drives to burn 700 or less than that...if i want mor i will sift to dvdwrit..in future.....
it gives write error while writing even 730 mbs on 800mb disc............
btw...nero 6.6.0.5...allows to write 715mb on 702mb local disk on disk at once(12mb overburning)........so guys take a note of it..........
magnet is offline
Old 13-01-2005, 06:34 PM   #29 (permalink)
I use Amkette 80mins CD and 52x32x52 Samsung and 52x32x52 BENQ writer.No problem with them.
lavanjoy is offline
