Old 08-12-2006, 04:26 PM   #1 (permalink)
Question pls help!!!!torrent problem!!!
I downloaded & installed azureus.when i start it the configuration wizard runs and whatever port i give,it gives a nat error.The downloads are working but really slow.Also i went to their troubleshooting page & their they something about portforwarding which i cannot understand.I have disacled all firewalls.I use an airtel gprs connection.they also say something about router.how can i find my router?Actually what is all this?What should i do to remove this nat error.
sesi5674u is offline
Old 08-12-2006, 07:51 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: pls help!!!!torrent problem!!!
are u with any ADSL connection ??
if yes then search in this forum... plenty of post regarding how to Port forward with BSNL / AirTel ADSL modems...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-12-2006, 08:25 PM   #3 (permalink)
I connect with airtel gprs using my Nokia6630 connected via usb cable
Old 08-12-2006, 10:01 PM   #4 (permalink)
Rebooting
well then u should not be expecting great Speed with GPRS connection... its usually 40KBps therefore at its best download may range between 4 - 6 kbps...
rebooting
ChotoCheeta.com
Old 08-12-2006, 10:18 PM   #5 (permalink)
datz not d real prblm.i want 2 avoid d nat error i encounter in azureus.also i want 2 make utorrent work 4 which i hav 2 do portforwarding.is dere any way 2 know d router 4 my airtel gprs connection?
Old 08-12-2006, 11:31 PM   #6 (permalink)
als2's Avatar
just forward ur port with port 23 in azureus configuration wizard .it will not give any nat error.
als2 is offline
