Old 03-12-2006, 10:39 AM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default virus problem plz help
while scaning computer by avg antivirus a virus(trojan horse generic2.jkz) was found in (c:/windows/sustem32/winosz32.dll), for the time being it has been kept in the virus vault, can I delete it from the vault, will it do any harm to my system if I delete it from the vault, plz reply ,.............
gau_pppu is offline
Old 03-12-2006, 10:52 AM   #2 (permalink)
Default Re: virus problem plz help
yes u can delete it
if it is windows file then it automatically restore it
u r using windows xp am i right ?
or just rename it
Thanks
minniawochat is offline
Old 03-12-2006, 11:06 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
its a nebular trojan. go ahead and delete it !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
