Old 01-12-2006, 02:39 PM   #1 (permalink)
anzaan's Avatar
Default my monitor is blank!! help
hi ppl...
i gt a problem. whenver i strart my pc, the monitor stays blank. i gt windows xp in my pc. the windows start properly bt nothing comes on the monitor ( how do i knw windows start properly? the starting and ending windows sound plays n also i m able to turn offf the systme using keyboard remembering the commands...).
i have the plugins everything is ok. i gt a tv tuner attched to my pc. the monitor as a tv works well bt it doenst shows anything on screen when i start my pc. i try to change the moitor bt the problem is same. perhaps the problem is nt with the monitor bt the CPU...
can anyone help waht is going on????
__________
also the monitor goes blue then black then blue then black....
what is it????
d a m n ! !
anzaan is offline
Old 01-12-2006, 02:44 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: my monitor is blank!! help
Attach the RAM properly......
Third Eye is offline
Old 01-12-2006, 02:46 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
MOst probably your Motherboard drivers (or gfx. drivers) are corrupt.
give details of your m/b model, dedicated gfx. card (if any)...
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 01-12-2006, 02:51 PM   #4 (permalink)
The Researcher
See the connections. If they are right, then most probably your display drivers have go corrupt. Install them again.
Ramakrishnan is offline
Old 01-12-2006, 02:58 PM   #5 (permalink)
anzaan's Avatar
i have a tv tuner attched to the same system and the monitor as a tv works fine. so is it still possible the display drivers has gone corrupt?? correct me if i m wrong
__________
okiee.. i will post tat soon. bt is there any solutions possible.. bcoz i cant see anythhing on the monitor.. how do i rectify things without seeing anything?/
d a m n ! !
anzaan is offline
Old 01-12-2006, 03:32 PM   #6 (permalink)
executioner's Avatar
switch it on!!!
Successful is one who gets what he wants and Happy is one who is satisfied with what he gets.
executioner is offline
