LinkBack (17) Thread Tools Display Modes
Old 25-11-2006, 11:07 PM   17 links from elsewhere to this Post. Click to view. #1 (permalink)
Question Folder lock problem, how to unlock?
Hi,
Some time ago I've used some of the older versions of Folder lock program (trial) and I had to format and reinstall Windows OS on my C: drive. The problem is that some of my files remained locked in a folder on D: drive and remain locked since then. I've contacted the suport of "Folder lock" but they said I have to be a registered user to give me the solution.
Does anybody know how can I get my files back, I don't want to use the program, just want to unlock my folder and get the files, then delete the folder.
Anyone knows how?
besteast is offline
Old 25-11-2006, 11:25 PM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default Re: Folder lock problem, how to unlock?
yes it can be unlocked. just see the contents of ur D drive in cmd prompt and checjk the current names of ur those locked folders.
u will finf the names in special symbols . Just note those symbols and then use Alt+ 250 onwards to check by hit n trial what symbol matches . then when U find all the symbols , use "cd" to move to that folder or rename it to ur desired name. I have cracked Folder lock many times in my college computers and some friends computers . it always work. best of luck.
n00b forever...
~Phenom~ is offline
Old 25-11-2006, 11:58 PM   #3 (permalink)
thank you, but I will have some problems with that, could you please type for the commands I should use in command prompt step by step?
Sorry for being so unexperienced!
besteast is offline
Old 26-11-2006, 12:11 AM   #4 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
ok , just goto cmd prompt ,
C:\D:
D:\
goto the folder where u placed ur locked folder or if u placed in D: directly , type dir and see the contents . take a scrrenshot and paste here , i will do the job for ya.
n00b forever...
~Phenom~ is offline
Old 26-11-2006, 12:30 AM   #5 (permalink)
OK,
the problem folder i called Folder Lock , DOS name is folder~1
it is on my secon hard drive - my old hard - on G: drive which is FAT
(previously it was created under win98, now I am using win XP and my main hard drive is NTFS)
I can access this folder, I can copy it everywhere but I don't exactly see its content in cmd
when I use the dir comand it shows 2 folders called "." and ".."
when I scan the folder lock folder with nod32 antivirus I see some strange symbols for the subfolders but I don't know how to type these special symbols...
strange things happening...
besteast is offline
Old 26-11-2006, 12:36 AM   #6 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
I have checked the attached pic. "." and ".." are default in every directory.dont worry about that. Now I think there is nothing in that folder or its hidden , try "dir /a" . check the properties of that folder. and post the screen shots of "dir /a" of both G: drive and that folder.
n00b forever...
~Phenom~ is offline
Old 26-11-2006, 12:46 AM   #7 (permalink)
ah, now it worked !
here is what it shows
I am sending also a screenshot of what nod32 shows:
besteast is offline
Old 26-11-2006, 01:05 AM   #8 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
the code is cracked , here it is . press ALT and then these numbers and u should get the desired folder name. Then u can cd to that folder or rename it in cmd prompt.
the numbers are
151 177 168 176 172 151
do tell me what happened.
n00b forever...
~Phenom~ is offline
Old 26-11-2006, 01:31 AM   #9 (permalink)
I don't know if I am doing the commands right but i can't rename it by now... doesn't work
besteast is offline
Old 26-11-2006, 01:38 AM   #10 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
goto G: , then to folder~1 , then dir
then try cd "that code"
n00b forever...
~Phenom~ is offline
Old 26-11-2006, 01:58 AM   #11 (permalink)
here's the screenshot
doesn't work
don't know why
how can I see the DOS names of folders and files?
the dir command gives "Folder lock" as folder name but I know from my win98 that the DOS name is folder~1, unfortunately winXP doesn't show DOS names in "properties" and command prompt also shows windows names
may be the problem is somehow related with that, I don't know
besteast is offline
Old 26-11-2006, 02:06 AM   #12 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
donno whats the problem. sorry cant guess whats the problem.
have u ever tried linux ???? once my friend said he successfully opened such folder in linux without any fuss. u may try a live CD.
try ur luck.
n00b forever...
~Phenom~ is offline
Old 26-11-2006, 02:19 AM   #13 (permalink)
I haven't used Linux but I may try the live CD
those guys from the support of Folder lock know how to deal with this but they won't say unless I buy the product, which i don't want to do.
thank you for the help anyway!
I think the problem is somehow related with the character set, may be this special character code is not the exact DOS name, how can I see the DOS names of files and folders in command prompt (and win XP)?
if "Folder Lock" = folder~1
then I don't know what this special character name is in DOS...
besteast is offline
Old 26-11-2006, 02:28 AM   #14 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
donno about that.
what u mean by DOS names ?? what u see in cmd ( not command ) by dir are actual DOS names.
n00b forever...
~Phenom~ is offline
Old 26-11-2006, 03:29 AM   #15 (permalink)
at last!
I opened "Folder Lock" and changed folder options in winXP unchecking "hide protected operating system files"
then I saw the strange folder named with the special character codes, it has been hidden, I renamed it to "new"
but when I click it, it shows control panel instead of subfolders and files
in cmd I can see the files now by dir command, I just have to copy them
how do I copy folders in cmd? I can copy files but I don't know what is the command to copy a folder?
__________
OK, CHEERS!
I figured it out!
I managed to copy the content with the xcopy command
the "hide protected operating system files" option was the key to the problem, after I unchecked it and was able to see the folder in windowsXP, I renamed it and then in cmd I could see its content with "dir" and copy the locked files and folders with "xcopy"
this is how it worked!
thanks for the help!
besteast is offline
Old 26-11-2006, 11:10 AM   #16 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
why dont u just copy all the files to a diffrent location???? why u want to copy the folder???? u want the files and not the folder ,right ?????
i m glad that u finally got ur files , though I was not of much use to u.
n00b forever...
~Phenom~ is offline
Old 26-11-2006, 05:42 PM   #17 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
You couldve removed the system attribute set by the crappy software by this :
Start > Run > cmd {press enter}
D:
attrib -s -h -r folder~1 {Press Enter}
The folder should be visible in Windows Explorer now. And then you could browse the folder easily.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 26-11-2006, 08:58 PM   #18 (permalink)
Yes, that is what I did, I copyed the content (files and folders) of the problematic special characters folder, not the folder itself. I deleted the folder with the strange (ASCII?) charcters after I copyed its content.
Everithing is OK now and I suppose I will never have this problem again, but it's good to know the solution
And also someon having the same problem might read this and find it helpful...
__________
D:
Thnaks,
we have another way of delaing with this problem then.
obviously the system attributes have been the key...
BTW, is this the reason why I couldn't rename it in cmd?
besteast is offline
Old 27-11-2006, 11:59 PM   #19 (permalink)
Well I suppose you were using command.com instead of cmd.exe and command.com doesnt support UTF character in filenames.
Old 23-10-2007, 05:10 AM   #20 (permalink)
hello
I have also this problem,
But I can't do,
could sombody tell me how to visibly??
Look my screen shot
http://img514.imageshack.us/my.php?i...derlockuk0.jpg
Lecson is offline
Old 04-11-2007, 08:58 AM   #21 (permalink)
help pleaseee
Lecson is offline
Old 05-11-2007, 02:32 AM   #22 (permalink)
How about trying
attrib -h -s -r * {Press Enter}
Old 21-12-2007, 09:23 PM   #23 (permalink)
Exclamation Re: Folder lock problem, how to unlock?
hey I also locked my very important folder by using folder lock and today when I tried to unlock the file is not there in the (browse>unlock) the folder is gone and I dont know how to find the dos name of the file. any help??
vi00097 is offline
Old 21-12-2007, 09:34 PM   #24 (permalink)
Let the music play.....
djmykey's Avatar
Wow why do all of y'all need a folder lock. Make it hidden and system files. Viola no one will b able to touch it. If you have a geeko sibling just name the folder such that it seems to be a system folder, so even if they unhide them they wont touch it.
djmykey is offline
Old 21-12-2007, 09:37 PM   #25 (permalink)
what do you mean.I only need to unlock my folder in D: volume any help dude?? now I wont trust any locking softwares.the problem is I installed folder lock and locked my very important folder and after a reboot when I looked to unlock the locked folder is gone.any help??
vi00097 is offline
Old 22-12-2007, 02:49 PM   #26 (permalink)
the folder i locked id d:\saaif and in the unlock menu the file is gone. oh I also deleted some file called hook.txt in C: I tried the above methods and couldnt find a solution help me really needed. very important files are in there.
vi00097 is offline
Old 10-01-2008, 08:51 AM   #27 (permalink)
How can i unlock a Folder Locked by PCSECURITY 5.3 without password ?
SUNIL84 is offline
Old 05-04-2008, 09:51 PM   #28 (permalink)
help me pleas
bonjour je viens vous demander de l'aide au secour plus que toujour
voila j'ai 2 partition, partition C et D
j'ai windows xp Sp3 experience
partition D je met tous mes document audio video photo ..................... dans ce disc D seulement mes fichier donc pas de programe instaler
partition C c'est pour windows ... tchater . msn ......
ya 2 jours javais un probleme 2 drivers carte son ......... j'ai demander de
l'aide sur msn puis j'ai accepter de faire de asistance a distance mais avant tous j'ai pris des precaution de mesure pour mon disc D alor j'ai telecharger folder lock et j'ai crypter mon disk d avec un mot de passe composer seulement des numero donc pas d'alphabet puis plus tard j'ai cliki pour ouvrir mon disc D pour ecouter une chanson folder lock ma demander le pass je lui donner mais la surprise et le choc que j'ai eu, me dit que le pasword et erroner j'ai tous essayer j'ai fait marcher mon serveux j'ai essayer de le supprimer j'ai tous essayer des recherche .............. s'il veut plait je suis sur le point de perdre tous croiyer moi c'est trop chere pour moi c'est comme si en pert un amant je voudrai simplement savoir si je formate de nouveaux mon pc bien sur le disc C et ce que je trouverai mon disc D normale comme je l'espere merci davance repander moi s'il vous plait hi les pro
helpmespeeckfrench is offline
Old 01-05-2008, 03:40 PM   #29 (permalink)
HELP HELP HELP
i have the same problem as Besteat can enyone HELP Me PLZ
~Phenom~ if you are hier plz Help
the codes are hier
Directory of l:\locker
04/30/2008 10:32 AM <DIR> .
04/30/2008 10:32 AM <DIR> ..
0 File(s) 0 bytes
2 Dir(s) 65,430,351,872 bytes free
L:\>cd locker
L:\Locker>dir /a
Volume in drive L is Lokaal station
Volume Serial Number is D00E-8EF5
Directory of L:\Locker
04/27/2008 07:13 AM <DIR> ?▒?░??
0 File(s) 0 bytes
3 Dir(s) 65,430,351,872 bytes free
Thanks
kian is offline
Old 18-05-2008, 12:42 AM   #30 (permalink)
never use this software. it is full of bugs. I mean when u use this software and electricity wents off then ur files r left vulnerable to other users. I stopped using this software and now going on with trucrypt which is an OSS
XtremeX is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/42135-folder-lock-problem-how-unlock.html
Bestandan Onzichbaar This thread Refback 18-10-2011 11:55 PM
проблем със заключена папка This thread Refback 13-08-2011 12:58 PM
PasswordOne : des remиdes а vos mots de passe ! - j'ai perdu le mot de passe de FOLDER LOCK This thread Refback 07-07-2011 12:05 PM
How to open a folder lock of a retrenched employee? - Yahoo! Answers This thread Refback 03-07-2011 01:29 PM
Problem mit Folder Lock - Freesoft-Board This thread Refback 31-05-2011 02:18 PM
проблем със заключена папка This thread Refback 03-05-2011 10:59 PM
ПЂПЃОїОІО»О·ОјО± ОјОµ folder lock - Insomnia.gr This thread Refback 18-03-2011 07:53 PM
How to open a folder lock of a retrenched employee? - Yahoo! Answers This thread Refback 01-02-2011 07:37 PM
How to open a folder lock of a retrenched employee? - Yahoo! Answers This thread Refback 30-10-2010 03:37 AM
PasswordOne : des remdes vos mots de passe ! - j'ai perdu le mot de passe de FOLDER LOCK This thread Refback 22-08-2010 04:15 PM
Proble de donnйes anec LOCK FOLDER XP This thread Refback 19-08-2010 10:06 PM
проблем със заключена папка - hardwareBG.com форум This thread Refback 06-08-2010 11:16 PM
PasswordOne : des remdes vos mots de passe ! - j'ai perdu le mot de passe de FOLDER LOCK This thread Refback 28-07-2010 09:50 PM
???????? ?? folder lock - Insomnia.gr This thread Refback 24-07-2010 03:56 AM
Folder lock - Nationaal Computer Forum This thread Refback 09-07-2010 12:09 AM
проблем със заключена папка - hardwareBG.com форум This thread Refback 29-06-2010 12:35 PM
[ASK] Menjebol Folder Lock versi 6.1.3 - KAORI Nusantara - Komunitas Anime Otaku Rakyat Indonesia This thread Refback 22-06-2010 07:53 PM
- by gforz
