Old 24-11-2006, 04:33 PM   #1 (permalink)
~[::BOoYaKa::]~
Default How to Compress mp3 files using Audacity??
I want to compress some big mp3 files using audacity, but dont know how to do it! Can somebody guide me to the same??
Thanx.
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 24-11-2006, 05:11 PM   #2 (permalink)
The Researcher
Default Re: How to Compress mp3 files using Audacity??
what do you mean ny "compress"? If you want to save in mp3, you will require lame mp3 codec installed.
Ramakrishnan is offline
Old 25-11-2006, 07:19 AM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
use a front end like cheetah audio converter or audio grabber.
Life is too short. Have fun.
ilugd is offline
Old 25-11-2006, 08:59 PM   #4 (permalink)
~[::BOoYaKa::]~
Thank you all, i found out myself using Audacity!
Thanx!
REY619 is offline
Old 26-11-2006, 01:31 PM   #5 (permalink)
k_blues24's Avatar
@ REY619, Using Audacity u can compress MP3 but not in gr8 proportion.
here is the solution it works 4 me may be to u too :
Edit ur MP3 files if they are songs then it has some streams without sound tracks on it at the starting & at the ending (waveform shows straight lines without any disturbance ) delet this part of file it will reduce file size for some extends.
If ur not high level listener, then reduce ur file bits from 32 to 24 or 16, it will not works for all the files everytime.
Also i want ot recommonded u that use "dBpowerAMP Music Converter" it is one of the best converter + compressor & it is free. Also one more tool is MP3Shrink.
If u want it then contact me.
__________
winmp3shrink :
http://www.softpedia.com/progDownloa...oad-29022.html
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
Old 26-11-2006, 04:29 PM   #6 (permalink)
ilugd's Avatar
dbpoweramp disables lame after 3 months or so quoting license restrictions. Why so?
ilugd is offline
