Results 1 to 14 of 14
  1. #1
    Apprentice gofeddy's Avatar
    Nov 2006
    Unhappy system mechanic 6
    hello
    i am having system mechanic 6. i heard it was a great utility. but it has slowed down my computer considerably. it takes a very long time for copying and pasting files. but my friend says he has no such problems. he has the same config as i have:
    p4 3 ghz
    1 gb ram
    160gb hd
    wat could be the problem?
  2. #2
    Distinguished Member anandk's Avatar
    Mar 2005
    Pune
    Default Re: system mechanic 6
    i think some of its components appear in the startup. remove them.
    praps u have some other problm, as sysmech does not slow down the pc.
    scan ur pc with ur av and as. else post ur hijacktis logfile here.
  3. #3
    Come get Some DukeNukem's Avatar
    Aug 2005
    Home Sweet Home
    Quote Originally Posted by Indyan
    I would recomend Tuneup Utilities as an alternative of Sys Mechanic.
    i Agree.
    while defraging my disk with sys mech. my pc goes dead duck.
    tune up is indeed a good softie
    Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
  4. #4
    gooby pls Third Eye's Avatar
    Apr 2006
    Not very far from you
    Quote Originally Posted by gofeddy
    hello
    p4 3 ghz
    1 gb ram
    160gb hd
    System Mechanic is not heavy,you must have installed heavy softwares.You should remove unwanted program from starup.
    Do this to remove unwanted programmes:
    Run 'msconfig' in run command and uncheck unwanted program from startup......
    Also never install NAV,it will kill your pc
  5. #5
    Beware of the innocent ilugd's Avatar
    Dec 2005
    system mechanic in itself should not be slowing up your pc. Agreed that it messes up sometimes, but it never does so in a subtle way. Your pc has some other worries. Try to sort it out.
    Life is too short. Have fun.
  6. #6
    Broken In amit2005's Avatar
    May 2006
    in front of PC
    Quote Originally Posted by DukeNukem
    well on first place it's not the software u want for defrag......go for best in buisness...DISKEEPER
    ROCK IS HERE
  7. #7
    Human Spambot Kiran.dks's Avatar
    Apr 2006
    Pune, India
    System Mechanic is a good software. It never slows down your PC.
    Try running 'PC Total care' in System Mechanic Power tools. If problem remains, then as anand said, there is some other thing like Virus slowing down your PC. Scan entire system with good antivirus software.
    Regarding Start-up's programs, System mechanic has got good 'Start-up Optimizer'. It disables unwanted programs.
    Kiran Kumar R
  8. #8
    Human Spambot clmlbx's Avatar
    Aug 2006
    Indore
    Smile Re: system mechanic 6
    yes, i do think system mechanic slows down pc
    i will advice u to use system mechanic mobile tool kit .
    It is like portable . u don't have to install it and it will run as good as installed one .
  9. #9
    Commander in Chief QwertyManiac's Avatar
    Jul 2005
    Quote Originally Posted by tech_mastermind
    Now there's a Sys mech fan who has got a 2 GB RAM along with blindness on time taken by it to operate
    Harsh J
    www.harshj.com
  10. #10
    Apr 2006
    Quote Originally Posted by QwertyManiac
    I have 1GB DDR 2 RAM Mr. and system mechanic is the best utility.....
    You are looking like NAV Fan
  11. #11
    TechTin.com ravi_9793's Avatar
    Jun 2005
    www.TechTin.com
    System mechnaics simply sucks the system resources.I will always recommend tuneUp Utilities.I have used both...so no dout in that.
  12. #12
    Apr 2006
    Some features in System Mechanic sucks but not the whole.......
  13. #13
    Jul 2005
    I dont have an anti-virus for that matter, nor a spyware checker. My PC is 512 MB ram and boots up from BIOS to OS in 7 seconds flat. I have tried and written up 3 reviews for System Mechanic 5, and 6. I know how heavy it is, cause I didnt know Tune Up existed back then.
    Harsh J
    www.harshj.com
  14. #14
    Mar 2005
    Pune
    i hav 256mb ram and sysmech 6 (not pro, ie without the av) doz not v me any prob. i use both, this n tune-up, though i m partial to the latter ! i hav removed its compnents frm d startups.
  1. Get System Mechanic For Free
    By Minion in forum Freeware
    Last Post: 18-02-2012, 07:06 AM
  2. System Mechanic 6 Pro
    By karnivore in forum Software Q&A
    Last Post: 15-01-2007, 08:01 PM
  3. System Mechanic 6
    By LegendKiller in forum QnA (read only)
    Last Post: 12-01-2006, 01:30 PM
  4. system mechanic 6.0 pro
    By COOLdeepak in forum QnA (read only)
    Last Post: 22-10-2005, 10:56 PM
  5. System Mechanic 5.5 released
    By allindrome in forum QnA (read only)
    Last Post: 05-02-2005, 02:53 AM
