Old 20-11-2006, 05:10 PM   #1 (permalink)
rohus24's Avatar
Default Antivirus help!!!!!!!!!
hi guys
i am going 2 format my pc today.
but i am confused on which antivirus to go for.
i currently have
1) kaspersky internet security 6.0
2) bitdefender v 10 internet security as the options.
which will provide better performance and gud virus dectection rates plus faster booting process.
plus ive heared of some issues with kaspersky with rediffmail. is it true?
plz throw some light on this.
thnx
Rohit...
rohus24 is offline
Old 20-11-2006, 06:22 PM   #2 (permalink)
Default Re: Antivirus help!!!!!!!!!
I have heard of many issues with Kaspersky. I would advice you on using Bitdefender....
yashved is offline
Old 20-11-2006, 06:27 PM   #3 (permalink)
Kiran.dks's Avatar
This never ending question keeps on popping up all the time.
Anyways,
I recommend KAV than Bidefender for medium configuration PC. Bitdefender all though equally good in detection rates, consumes more resources. It is good for High-end PC's.
Kiran Kumar R
Kiran.dks is offline
Old 20-11-2006, 06:35 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
have used both. of these 2 i suggest (i use kis too) u kis 6.0. read more about kis here
click here for a soln to the minor issues betn rediffmail/kis.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 20-11-2006, 08:27 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Go for "kaspersky internet security", it works gr8
Ask "Saurav_cheetah" about it, he is also using it
http://www.AskVG.com/
Vishal Gupta is offline
Old 20-11-2006, 08:28 PM   #6 (permalink)
Tech Geek's Avatar
kaspersky is good than bitdefender
Tech Geek is offline
Old 20-11-2006, 08:32 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Between them two, I'd get Kaspersky.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-11-2006, 08:47 PM   #8 (permalink)
rohus24's Avatar
thnxxx guys ill switch over 2 kis
rohus24 is offline
Old 21-11-2006, 02:29 AM   #9 (permalink)
PrinceHeart's Avatar
Get NOD32.. from eset - forget everything else
*PrInCe*
PrinceHeart is offline
Old 21-11-2006, 10:02 AM   #10 (permalink)
piyush gupta's Avatar
Read this
Browser Fanboyism !
although its for browsers but will applicable on all ur choice of s/w for ur PC
me personally using kasperkey after trying out
NAV Mcafee bitdefender & NOD32
now its ur choice as i think this article will change ur point of view
piyush gupta is offline
Old 21-11-2006, 11:27 AM   #11 (permalink)
aryayush's Avatar
Do not use BitDefender. I was using BitDefender 9 Professional. Whenever I right-clicked on a file and scanned it manually, BitDefender used to delete it from the system, and that too, when the file did not have any infection. I downloaded Windows Vista RC1 from Microsoft's official site and, like a total idiot, ran it through BitDefender's scanner. The stupid thing deleted my 3.6GB ISO and I had to re-download the whole thing.
They might've fixed it in this version though.
Miss me already? See you on Penned Thoughts [http://aayush.me] then. Adios!
aryayush is offline
Old 21-11-2006, 12:58 PM   #12 (permalink)
rohus24's Avatar
thnx piyush
rohus24 is offline
