Old 20-11-2006, 11:40 AM   #1 (permalink)
shashank_re's Avatar
Thumbs down Vista Audio problem?
Iam using vista RTM version.Iam quite happy with it.But i noticed that it has heavy sound problems.
When i pause any Mp3 file, sometimes it doesnt resume and sometimes it resumes perfectly!! And even if i restart media player,it doesnt play the file(any file). And i have to restart my computer to play any song!
i heard that MS has changed the audio architecture in vista.
i have reinstalled my soundcard drivers(Intel onboard) and i have also installed all the codecs required.Even then it didnt solve my problem.
It irritates a lot as i have to restart my computer to a play a songAnd vista takes hell lot of time to restart.
What is the solution for this?
Note: THIS PROBLEM IS WITH ALL THE MEDIA PLAYERS OF VISTA(real,VLC,WMP 11etc)
shashank_re is offline
Old 20-11-2006, 11:47 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Vista Audio problem?
What code error message is displayed while you try playing the media file? Which WMP version do you have?
Kiran Kumar R
Kiran.dks is offline
Old 20-11-2006, 11:58 AM   #3 (permalink)
iam not getting any error code.iam using WMP11.I have this problem even if i play with other media players.
Old 20-11-2006, 12:07 PM   #4 (permalink)
Kiran.dks's Avatar
I guess it must be Audio or Video driver problem. You said that u have already reinstalled the drivers. But make sure it must be latest drivers. Check out Intel website for latest driver updates. Also update your Video drivers.
Kiran Kumar R
Old 20-11-2006, 12:25 PM   #5 (permalink)
I have done everything.Iam able to play the files without any problem in XP.
Old 20-11-2006, 01:03 PM   #6 (permalink)
Kiran.dks's Avatar
There are no known problems in Vista w.r.t playing the media files. System files must have got corrupted.
Run the command sfc /scannow. Windows will scan the system files and will verify missing or corrupt files. Insert Vista CD if prompted.
Kiran Kumar R
Old 20-11-2006, 11:22 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
yes...I have vista running gr8.I hv no problem with audio or video.U better try @kiran.rkk method.Else u can do like this.
Boot the system using vista DVD.selet pair ur computer....than it will show some optins.From there u cann correct ur vista currpt problem.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Old 21-11-2006, 10:39 AM   #8 (permalink)
aryayush's Avatar
Mind posting your hardware configuration? Because Vista is supposed to boot up and shut down faster than Windows XP.
Miss me already? See you on Penned Thoughts [http://aayush.me] then. Adios!
aryayush is offline
Old 21-11-2006, 09:10 PM   #9 (permalink)
My PC config :
P4 3.0HT
512MB RAM
Asus P4P800-VM Motherboard
Nvidia 6200 Graphics card(256MB)
Old 21-11-2006, 09:39 PM   #10 (permalink)
aryayush's Avatar
Oh, that is a pretty under-powered PC. I would suggest you to use XP. Vista is very slow on 512MB of RAM, which you must know by now. And don't enable Aero even if it is available. Or better still, add another 512MB of RAM, they are very cheap these days.
aryayush is offline
Old 21-11-2006, 11:11 PM   #11 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Umm.. are you running XP drivers for sound on vista?
kalpik is offline
Old 21-11-2006, 11:24 PM   #12 (permalink)
TechTin.com
ravi_9793's Avatar
Well 512Mb of of ram is sufficient for vista.I hv vista running very smooth on 512mb ram.I will also suggest u nt 2 use aero on 512mb ram.
Well u can do 1 thing..update driver...n repair ur vista if problem continues.
TechTin.com
Old 21-11-2006, 11:37 PM   #13 (permalink)
assasin's Avatar
I'm using Windows Vista RTM too and using Win XP drivers for my onboard sound (Sound Max),but i dont have any probs playing audio/video even when running other apps.
assasin is offline
