Old 19-11-2006, 08:32 PM   #1 (permalink)
Question How To Overclock
What Is Overclocking And How Can I Do It.
P4 1.8.. 128ddrram. 533mhzfsb. Etc
aatuif is offline
Old 19-11-2006, 08:59 PM   #2 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Default Re: How To Overclock
common man.........search this forum before posting........there have been umpteen threads on Overclocking.......
Thread reported
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 19-11-2006, 09:40 PM   #3 (permalink)
jz2linkinpark's Avatar
First,in the BIOS set the RAM clock on FSB level(ratio 1:1) and lock the AGP/PCI frequency on 66/33 Mhz
Raise the CPU core voltage from 1.38 v to 1.50 v.
Increase the FSB clock from its standard 133 Mhz speed in 10 Mhz steps,each time testing the stability of the system under full load-the CPU temperature should remain below 65'C
and to check performance increse use benchmark such as everst or sisandra
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 19-11-2006, 10:19 PM   #4 (permalink)
samrulez's Avatar
I don't think original intel/mercury etc...board have options for Overclocking..........and if South Bridge etc is not locked from the main bus you'll lose you HDD also..
Sam Rulez
samrulez is offline
Old 20-11-2006, 09:25 AM   #5 (permalink)
overclocker's Avatar
First of all this is a very common issue so if u wanted to know about it then best option for u seach it frm google.
overclocker is offline
