Old 19-11-2006, 08:28 PM   #1 (permalink)
lalam's Avatar
Default Help Me!!!!
I've been keeping on seeing this msg since yesterday while i was surfing......
I really don't know what to make of it! I did run the virus scan and the spyware scan too yesterday right after receiving the message but its back again. I use Avast home edition, Spybot and Trend Micro Scan. There has been no specific change in the performance of my computer though but this sort of alerted me and please guys i need help. I use Firefox as my browser.
lalam is offline
Old 20-11-2006, 07:23 AM   #2 (permalink)
vasulic's Avatar
Default Re: Help Me!!!!
It is a traking cookie .Scan your system Using windows live onecare this will solve your problem.
vasulic is offline
Old 20-11-2006, 08:06 AM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Use CCleaner to clean your whole system from cookies and unwanted files.It can be found at http://www.ccleaner.com/.
Check if this solution helps.
Nokia N86 8MP
Lucky_star is offline
Old 20-11-2006, 08:59 AM   #4 (permalink)
overclocker's Avatar
Data Miners (Tracking Cookies) are cookies that are used by two or more Web sites to track a user's Web habits for the purpose of providing the user with ads or other material that the user might be interested in.Similar to adware, data miners can collect a user's information for a third party recipient.
Solution:
The best solution is u scan ur system through HouseCall - Trend Micro's online virus scanner.
For that u visit this link: http://housecall.trendmicro.com/
overclocker is offline
Old 22-11-2006, 04:22 PM   #5 (permalink)
lalam's Avatar
Thanks Guys! Problem solved........
lalam is offline
Old 22-11-2006, 04:47 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
ya, its trend micros damage cleanup service in action
good to hear ur problem was solved.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-11-2006, 05:04 PM   #7 (permalink)
vasulic's Avatar
how did u solve your problem?
vasulic is offline
