Old 19-11-2006, 02:36 PM   #1 (permalink)
bizzare_blue's Avatar
Default Peculiar mp3 playback problem
Yesterday, I downloaded an MP3 album from internet but when I tried to play the files in WMP10, it reported the following error...
C00D11CD: Unknown error
Windows Media Player encountered an unknown error. This can occur when another program or operating system component encounters a problem but does not communicate the nature of the problem to Windows Media Player.
Error ID = 0xC00D11CD, Condition ID = 0x00000000
Then I tried to play these files in Real Player but it showed same type of error...and to top it all there is no explanation for this error on their sites...
When I played these files using media player classic(I have k-lite mega codec pack 1.60)...the files played without a hitch...Is it possible to play these files in WMP and Real Player? If yes, then plz explain how...
Bitten by the open-source bug...
bizzare_blue is offline
Old 19-11-2006, 03:06 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Peculiar mp3 playback problem
Check out the name of the file. It must not be too long.
Rename the file to a single word and try again.
Kiran Kumar R
Kiran.dks is offline
Old 19-11-2006, 04:16 PM   #3 (permalink)
@kiran.rkk
I renamed all the files but the problem still persists...
Old 19-11-2006, 04:40 PM   #4 (permalink)
Kiran.dks's Avatar
It is a 'General' error code..
So you don't have single reason for it.
Check whether system files are missing or corrupt.
Click Start > Run and type sfc /scannow .If anything is wrong, system will prompt for Windows CD. Then it will automatically replace missing or corrupt files.
Then try opening the file.
Kiran Kumar R
