Old 18-11-2006, 10:57 AM   #1 (permalink)
Default Help ...!
Hi all,
My dad's pc was infected with Win32FunLove virus since quite a time... now as my exams were over he told me to get rid of it as even formatting didnt help. I ran many anti fun love utilities given in various sites , and in the end found one useful which did it in dos mode. "http://www.symantec.com/avcenter/Fixfun.exe"
I downloaded this on the other comuter which isnt infected.
i booted and ran the portable 98 floppy and ran the utility. Then i reinstalled windows 98. Now the computer doesnt start and shows errors of Unregmp2.exe and hpboid.exe.
Can anyone tell me what should i do next.
Er... urgent
KMKM is offline
Old 18-11-2006, 01:06 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
i take it u have run all the anti-funlove utilities. now try the antibride.exe tool by running it in safe mode. HOPE it starts in safe mode atleast.
The BullGuard antibride.exe tool does the following:
it detects all the known Win32.Bride versions;
it deletes the files infected with Win32.Bride;
it disinfects the files detected as Win32.Funlove;
it kills the process from memory;
it repairs the Windows registry.
http://www.bullguard.com/virus/default.aspx?id=7
reg the unregmd2.exe error try this :
press Shift +F10 to bring up the
command prompt. Then type taskmgr.exe in the DOS window
and press Enter. The Task Manager should be started. If
not, try to press C+Shift+ESC. In the Task Manager
program, select the error messsage window in the
application list and click "End Task". In the process
list, terminate the unregmp2.exe program. Exit the DOS
prompt window and resume the installation process
http://www.techspot.com/vb/topic12158.html
if u can, delete this entry if it exists it :
HKEY_LOCAL_MACHINE\software\microsoft\windows\curr entversion\runonce\kb837272
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-11-2006, 01:18 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Default Re: Help ...!
simple thing is to reformat & reinstall win98
Win98 has many of these kinds of Prob. to get ride of this upgrade ur win98 to WinXP
its much better & safer than previous ones............
satyamy is offline
Old 18-11-2006, 02:01 PM   #4 (permalink)
ketanbodas's Avatar
He has already reformatted 1ce...how many times shd he reformat. But ya upgrade to xp now dude .
Life is like a game - Enjoy playing it.
ketanbodas is offline
