| Forum |
#1 (permalink) |
when i see any folder properties its showing read only atribute, i removed the readonly atribute and saved doing OK. but when again open its property its showing the same readonly atribute. how could i remove that read only atribute. pls help......... |
#2 (permalink) |
Posts: n/a
if you notice then there are three variations of the check-box.
* blank (not read-only) * checked * box-filled (the check-box is filled with a green square) Enable/disable readonly but when you see the properties again you'll see the 'box-filled' version. Its not a problem, you folder was marked "write-also) ( *wonders why MS did this* |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
