I d/l Adobe Acrobat Pro. 8 Trial & when try 2 install..the setup screen splashes AND the setup never runs. While trying to extract files using "Univeral Extractor 1.3" i got the following msg.
{http://i134.photobucket.com/albums/q88/blackpearl75/UE_Acrobat8Trial_Error.jpg}.
Do i need to install some files ??? I am successfully running Acrobat 7.0.8.
Kindly Help !!!
Regards
__________
Originally Posted by blackpearl75
I d/l Adobe Acrobat Pro. 8 Trial & when try 2 install..the setup screen splashes AND the setup never runs. While trying to extract files using "Univeral Extractor 1.3" i got the following msg. {http://i134.photobucket.com/albums/q88/blackpearl75/UE_Acrobat8Trial_Error.jpg}.
Kindly Help !!!
Regards
My OS is WinXP SP2/AMD/512MB/AGP8x
