Old 10-11-2006, 12:23 AM   #1 (permalink)
Default How to connect 2 systems using a hub
Hi All
i need some help, i have 2 sytems which i want to connect
one with win98,winxp ,other with winxp,media center os loaded i would like to know how to connect them using intex 8-port hub in winxp
i would reguest you to give me a step-by-steps to configure
thank you
John
axil_joihn is offline
Old 10-11-2006, 11:30 AM   #2 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Re: How to connect 2 systems using a hub
ok so u have two pcs. first let me tell u wat all hardware u need. u need a 8 port hub, 2 ethernet cards one for each pc and patch cable (CAT5) make sure they are crimped at both ends. one end will connect to ur ethernet card and the another end to ur hub.
secondly u need a software called proxy server like <analog proxy free download available on net> instructions are given along with installation, just follow them and u r done. share net, share filez and printer.
if u find this helpful pls add to my reputaion.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 10-11-2006, 04:02 PM   #3 (permalink)
hi thanks for the info.. it was usefull is there any other way to directly connect in win xp using workgroup...i have all the reguired hardware but not able to configure it ... any websites,step-by- step manual will be very helpfull
Old 10-11-2006, 04:30 PM   #4 (permalink)
ya u can connect directly .... u only need network cards in both compu....
and a cross wire..... ask the vendor to give wire for connectin laptop and a desktop ...he will give it to u... join .....and then make IP's compatible and BINGO!!!!! ....its so easy it seems.....but not so...there are often troubles....i have experienced ...but off late they get resolved...
who the hack is this??
mukul is offline
Old 11-11-2006, 01:43 AM   #5 (permalink)
hi there i am aware of cross cable to connect 2 system without a hub....
but i need to use the hub as i might connect more systems in future ..
pls someone help me out abt how to connect 2 systems in winxp using a hub// r how to create a workgroup for which i will be very greatfull
thank u
Old 11-11-2006, 10:16 AM   #6 (permalink)
sysfilez's Avatar
yes all ur machines have to be in the same workgroup (give a certain name like home, mshome, workgroup etc)after u have done all the neccessary connections open ur network connections from general>select internet protocol tcp/ip> properties> use the following ip. there u define the ip addresses. make sure u have ip address in series like for ur first pc 10.0.0.1 and second 10.0.0.2 and so on with subnet mask 255.255.255.0 same for all pcs. this will solve the problem. go for a hub connection coz it will be much more faster than cross cabling. njoy.
sysfilez is offline
Old 13-11-2006, 12:30 AM   #7 (permalink)
hi there thank u all for all your inputs it was really helpfull
i am faced with one more problem now..when setting up a small office/network wizard in winxp after asking me to install the network startup frm the win xp cd when clicking on my network places i showing blank saying that i do not have auth to view // r set up this network
workgroup choosen was MSHOME on both the systems using admin profile..
pls help me our guys
Old 13-11-2006, 04:00 PM   #8 (permalink)
Disable the Windows Firewall on both the machines.
bandwest is offline
Old 14-11-2006, 01:16 AM   #9 (permalink)
yes the firewall is disabled on both the systems but still the same message comes
__________
guys anyother thing i can try pls let me know ....... thanks in advance
