Old 09-11-2006, 02:33 PM   #1 (permalink)
kumars's Avatar
Default Problem with PC Suite connectivity..
Guys i am able to surf internet through GPRS by using data cable on my computer.. But when i want to transfer files using any PC Suite (i've 6.8) then software doesn't detect my Nokia Communicator.. My phone gets detected by PC Suite on another computer easily but not on mine!!?
Kumarpal Shah
kumars is offline
Old 10-11-2006, 11:08 AM   #2 (permalink)
kl_ravi's Avatar
Default Re: Problem with PC Suite connectivity..
Do you see nokia phone browser in "My Computer"
Which service pack are you running.
Which version/release of Nokia PC suite
Which mobile are you using
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 10-11-2006, 12:02 PM   #3 (permalink)
De@d
outlaw's Avatar
try bluetooth instead of data cable
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
Old 10-11-2006, 12:21 PM   #4 (permalink)
kirtan's Avatar
may be the connection preferences have not been set.open pc suite and then go to manage connections.u can see the kind of connection preferences like bluetooth,ir,dku-2 etc.check the box with the appropriate connection of your choice.
Water can flow or it can crash.Be Water my friend.
kirtan is offline
