08-11-2006, 09:19 PM
XP problem URGENT
total capacity of my C: is 5GB(where XP is installed)
now only 1.75 GB is left
when we hibernate a file is saved(ram size 128MB)
i want to delete all those files
i want to increase the empty space in C:
NOTE: All the results to be posted by tommorow 8:30PM
08-11-2006, 09:39 PM
gooby pls
Re: XP problem URGENT
If you disable hibernate then you save 128MB Disk Space(because your RAM is 128MB)
08-11-2006, 09:57 PM
a_g = JPKN
=>disable/ turn OFF the "System Restore" points only in that Drive.
=>move the "My Documents" folder to other drive.
=>& you can also move the "Program Files" folder to other partition. (or install the new Application in other partitions.
ASUS K53SV SX520D + BF3
08-11-2006, 10:09 PM
Microsoft MVP
1.) Disk Cleanup
2.) Empty Temporary Internet Files
3) Empty Temp folder
4.) Empty Prefetch folder
5.) Search for following files and delete them:
mscreate.dir;whatsnew.*;*.tmp;*.log;*log.txt;*read me.txt;file_id.diz;tips.txt;*.bak;*.old;*.syd;*. pr v;*.grp;*.gid;*.fts;*.cnt;*.~mp
6.) Disable System Restore
7.) Look for "$random letters$" folders (HIDDEN) in "C:\Windows" folder and remove them, these r backup folders, which r created by Automatic Updates!
09-11-2006, 08:32 AM
Come get Some
well you can try the above mentioned
but i would like suggest to either increase your C drive partition size.
if not possible try upgrading.
as 5GB for OS is good till windows 98SE, you need to try atleast 10 gb for windows XP if you need to install a few good programs with it.
and if you apply service pack to it it will go beyond 2.4 gb+ (just windowsXP and Servicepack 2) add office to it 550MB+, see what you need is bit large partition.
system restore feature will eats up plenty of your presious space. dissable it.
from time to time empty your temp folder (use cleantemp for this free one and erase your temp folder contents every time you boot), empty the cache of the browser you uses (they have this feature which empty the cache when you close the browser).
do not empty prefetch folder too often as it will decrease your system performance
though i would not suggest to dissable hibernation as for its feature but if you do not use this dissable it to from control panel's power option.
shift the paging file to some other drive of your hdd (if you have space on them) other than your C drive
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
09-11-2006, 09:00 AM
Distinguished Member
uce freeware 'ccleaner' to automate ur junk removal tasks. www.ccleaner.com
clearing the prefetcher say once in a long while is, well, ok.
use xp diskcleanup utility to compress old files.
i prefer to keep systemrestore 'on'. never know when it may come in handy.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
09-11-2006, 09:50 AM
Decrease the amt of space reserved for use in Recycle Bin.
09-11-2006, 09:05 PM
turn off virtual memory from that Drive
09-11-2006, 09:12 PM
is there any way to delete the files which are created when we press hibernated???
i don't want to remove the turnoff option
@dukenukem i have alredy incresed the size of C:/ from 3.75GB to 5GB
i don't want to increase it anymore
09-11-2006, 09:19 PM
Livin' in the ghetto
Yes the file can be deleted, from Tools--> Folder Options disable the option to Hide protected Operating System Files and then u'll see the file there name should be hiber something. Make sure your last reboot was complete shutdown and start and delete the file.
I would suggest enabling compression on the drive and moving the My Documents and Program Files Directories to the other drive as well.
Nd yes Hardware is the cheapest thing nwdays ... increase ur HDD
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
09-11-2006, 10:13 PM
change the virtual memory.
Rightclick-my computer>advanced>Performance-settings>advanced>Virutal mamory-change...........
it might help
10-11-2006, 06:36 PM
The files are store on the allocated space for virtual memory. set " no paging file on that drive" it must increase your free space.
10-11-2006, 08:49 PM
Thanks for all of ur suggestions
my problem was almost solved
10-11-2006, 08:55 PM
Almost .... Whats Left ?
10-11-2006, 08:59 PM
i haven't done 2 things which have been written above
10-11-2006, 11:44 PM
Coming back to life ..
When you enable hibernition, a file with size equal to your RAM size is created (hiberfil.sys) . If you dont want this file, you'll have to disable hibernition do this :
Start > Run > powercfg.cpg <Press Enter>
On the Hibernition tab, Uncheck the option of Enable Hibernition
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
11-11-2006, 12:35 AM
i think nothing left here which can be applied to free space in C drive
do there left...?
11-11-2006, 12:45 AM
Microsoft MVP
One more thing can be done!
If WFP (Windows File Protection) service is disabled, then we can safely remove %windir%\System32\Dllcache folder, it contains a backup of all system files and its size is between 500MB-1 GB approx.
I always disable WFP service and then remove this folder to free space
11-11-2006, 12:53 AM
#19 (permalink)
@Vishal, That System backup directory '%windir\System32\Dllcache' is there for a purpose!!
What is you/someone accidentally deletes a System file? You can restore it from there.
I think you get my point. Otherwise you have reinstall Windows.
* Imagination is more important than knowledge.
-Albert Einstein
11-11-2006, 12:57 AM
#20 (permalink)
Microsoft MVP
We can also restore the required file from the Setup itself
All files can be extracted from XP setup CD
And if we hv disabled WFP service then this directory is useless! And we hv to disable the WFP service if we want to hack system files, like explorer.exe, etc frequently for resource hacking
11-11-2006, 01:03 AM
#21 (permalink)
@vishal how can we disable WFP & how can we extract required file from setup please explain
11-11-2006, 01:06 AM
#22 (permalink)
Microsoft MVP
To disable WFP Service simply go thru following thread:
List of Some Useful System Utilities!
And to extract the required file from setup, just search for that file!
Remember that file will be in compressed form, like shell32.dll file will be shell32.dl_
But u can extract them, either use 7-ip or WinRAR to extract them or simply give following command in DOS:
expand shell32.dl_ shell32.dll
