Old 02-11-2006, 03:47 PM   #1 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default pls help restore my icon
i dunno but somehow my d drive icon has changed to somewat like this. chek the pic. i want to restore it to look like others. pls help. also pls lemme know y this happened.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 02-11-2006, 07:47 PM   #2 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Default Re: pls help restore my icon
@sysfilez I guess there's some software copied from CD into the root of your D drive. Try moving it into a folder under D drive.
An alternative would be to look for an "autorun.inf" in the root of D drive and delete it if there is one.
If the above two does not work, get a thirdy party tool (like IconPackager/Desktop architect) and you can restore the icon using them
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 02-11-2006, 08:05 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Also check this:
In regedit goto:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer
And make sure there is not key DriveIcons under it and if its there, then it should contain a sub-key d and its value will be an icon path
So delete the DriveIcons key, if its there!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 02-11-2006, 08:09 PM   #4 (permalink)
Tech Geek's Avatar
This had happend to me when i had stopped the autopatcher installation at half.
Thans vishal
Tech Geek is offline
Old 02-11-2006, 08:11 PM   #5 (permalink)
Kiran.dks's Avatar
Download and run this registry entry.
Important: Take a registry back-up before doing so.
Link : Restore shell icons
Source: kellys-korner
Kiran Kumar R
Kiran.dks is offline
Old 03-11-2006, 11:11 AM   #6 (permalink)
sysfilez's Avatar
thanks mod, i restored my icon ur way.
sysfilez is offline
Old 03-11-2006, 12:02 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
u can also use tweakui > 'repair icon cache' option.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
