Old 24-10-2006, 09:54 PM   #1 (permalink)
vasulic's Avatar
Default System32 folder opens when computer starts
Hi, Guys
I have original windows xp pro OS (installed a few days before)
When ever I start my computer, System32 folder opens automatically .how o fix this problem?. Pls help
vasulic is offline
Old 24-10-2006, 10:17 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: System32 folder opens when computer starts
Try this, open regedit and goto:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Run
and make sure that there is no entry with strange characters or with " "
If its there, then simply delete the entry
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 25-10-2006, 06:06 AM   #3 (permalink)
vasulic's Avatar
hi VISTA,
Iam having the following entries in regedit. Now, tell me which entry needs to be corrected
(default) reg_sz (value not set)
Alcmtr reg_sz ALCMTR.EXE
hotkeysCmds reg_sz c:windows\system32\hkcmd.exe
igfxtray reg_sz c:windows\system32\igfxtray.exe
OnecareUI reg_sz "c;\programfile\microsoft windows onecare live\winssnotify.exe"
QuickTime Task reg_sz "c:\programfiles\quicltime\qttask.exe"-atboot
RTHDCPL reg_sz RTHDCPL.exe
Windows defender reg_sz "c:\programfiles\windowsdefender\MSASCui.exe"-hide
tclockEx reg_sz crogramfiles\tclockexe\tclockex.exe
yahoo pager REG_SZ -quiet
vasulic is offline
Old 25-10-2006, 01:31 PM   #4 (permalink)
Microsoft MVP
It'll be better if u export those 2 keys data from Registry and then paste the code here
Actually there r some typing mistakes in the above code!
Old 25-10-2006, 04:04 PM   #5 (permalink)
vasulic's Avatar
Hi Vista,
Hi, vista thank you , I have posted my registry entries as requested by you. But just an hour back I have fixed the problem by deleting the entry yahoo pager REG_SZ -quiet
"I have now learned how to copy ,paste registry entries'
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run]
"HotKeysCmds"="C:\\WINDOWS\\System32\\hkcmd.ex e"
"High Definition Audio Property Page Shortcut"="HDAShCut.exe"
"RTHDCPL"="RTHDCPL.EXE"
"Alcmtr"="ALCMTR.EXE"
"Windows Defender"="\"C:\\Program Files\\Windows Defender\\MSASCui.exe\" -hide"
"OneCareUI"="\"C:\\Program Files\\Microsoft Windows OneCare Live\\winssnotify.exe\""
"QuickTime Task"="\"C:\\Program Files\\QuickTime\\qttask.exe\" -atboottime"
"IgfxTray"="C:\\WINDOWS\\System32\\igfxtray.ex e"
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Run]
"TClockEx"="C:\\Program Files\\TClockEx\\TCLOCKEX.EXE"
vasulic is offline
Old 25-10-2006, 09:37 PM   #6 (permalink)
Microsoft MVP
Good!
So Yahoo! entry was causing the problem, as I thought
