Old 19-10-2006, 09:02 AM   #1 (permalink)
ferrarif50's Avatar
Angry Problems with IE 6.0
Hi,
I am using IE 6.0 with Windows XP SP 2, in a corporate environment.
I get a script error dialog box, whenever I visit any website outside the intranet (ie in the internet).
Sometimes I get the error repeatedly, until I close the website.
The error says the following:
An error has occured in the script in this page
Line: 2
Char: 1
Error: Syntax Error
Code: 0
URL: <any website>
Note, I get the same error always.
Any clue?
PS: Dont ask me to change the browser, as I am within my corporate limitations and provoke an other browser war here.
ferrarif50 is offline
Old 19-10-2006, 09:07 AM   #2 (permalink)
:-o
aakash_mishra's Avatar
Default Re: Problems with IE 6.0
This is an error caused due to syntax of java script..........
It can be corrected by editing its source.
www.amiable.in
aakash_mishra is offline
Old 19-10-2006, 09:19 AM   #3 (permalink)
ferrarif50's Avatar
Thumbs down Re: Problems with IE 6.0
Ha.. dude, I know the error box comes up if theres an error in the Java script. I am a web developer myself.
The problem I am facing is, I get the same error, for any website I visit. So, i feel inherently there is a problem with IE.
Any suggestions?
Old 19-10-2006, 09:29 AM   #4 (permalink)
:-o
Try this but on your own risk I haven't tried it
To resolve this issue, follow these steps:
Click Start, and then click Run.
In the Open box, type " Regsvr32 urlmon.dll ", and then click OK.
When prompted with the DllRegisterServer in urlmon.dll succeeded message, click OK.
If this not works then go for this:
Click "Start", click "Control Panel", and then double-click "Internet Options".
Click the "Advanced tab".
Under Browsing, click to clear the "Enable third-party browser extensions" (requires restart) check box.
Restart Internet Explorer.
If this not works the go for this:
Open "Internet Explorer".
Click "Tools", and click "Internet Options".
Under "Browsing", click to select the "Disable Script Debugging check box".
Click "OK" to close all windows, and then restart the computer.
if not then go for instaling Java virtual machine
www.amiable.in
Old 19-10-2006, 09:47 AM   #5 (permalink)
ferrarif50's Avatar
Hi,
Thanks, but I had already tried all the steps you have mentioned, quite sometime back.
The problem persists.
Old 19-10-2006, 10:30 AM   #6 (permalink)
:-o
Could you please tell me which are those sites??????????
www.amiable.in
Old 19-10-2006, 10:43 AM   #7 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: Problems with IE 6.0
Which one of those do u use - IE 6.0 or IE 6.0 SP 1 ?
techtronic is offline
Old 20-10-2006, 05:23 AM   #8 (permalink)
Better yet , switch to opera/firefox.
jeetu is offline
Old 20-10-2006, 01:49 PM   #9 (permalink)
ferrarif50's Avatar
Duh! I told that I am under corporate environment restrictions. IE is the standard here.
@aakash,
I already have said that, it happens with all the sites.
My time machine will take you one hour into the future in only sixty minutes!
Old 20-10-2006, 08:12 PM   #10 (permalink)
Distinguished Member
anandk's Avatar
have u tried these all, too ?
go to the advanced tab in internet options and scroll down to the browsing section and uncheck "display a notification about every script error", then scroll down to the java section and uncheck "java logging", then search "disable script debugging" and check it.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
