| Forum |
#1 (permalink) |
Help needed..plz |
#2 (permalink) |
Hi pushkar , does it show a countdown like " Shutting Down in 60 secs " or something like that .
IF that's so it's the SASSER worm . neways try typing 'shutdown -a ' in run . update ur anti-virus & if it detects the vius/worm 'SASSER' go to ms.com & u can find the removal tools for it. |
#3 (permalink) |
Distinguished Member
yes pushkar, give more details, is there such a countdown as mehrarakesh has askd ? if yes click system shutting down: please save all work in progress and log off
> www.TheWindowsClub.com < = www.WinVistaClub.com = Microsoft® MVP |
#4 (permalink) |
There is no such countdown......if the file is small it gets downloaded eg if file size is 200kb it gets downloaded....but if file size is more ie.1mb or more then the download starts and suddenly after couple of seconds comp gets restarted.I hav seen this type of problem 1st time....help me.....
Make it fast... |
#6 (permalink) |
Booting Nicotine!!
do u have sp2 ?
http://spironox.blogspot.com Rig : Asus P4 p 800SE ( happy ) Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004) |
#7 (permalink) |
i cant report my problem to microsoft bcos like everyone else i dont have licenced copy of windows
yes 1 hav sp2. ..ty. __________ what else should i do...will those download managers help me? Last edited by pushkar1986; 21-10-2006 at 09:37 PM. Reason: Automerged Doublepost |
#8 (permalink) |
check ur power supply for realiability issues and also try to run the computer in safe mode for sometime and see if it works fine or not?
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution |
#11 (permalink) |
Livin' in the ghetto
I've seen this issue occur due to some issue with AntiVirus, where over slow internet connection if the complete file is'nt downloaded within the timeframe the AV causes the system to reboot.
Make sure your AV is up to date and then try again. Also try monitoring the processes working on your computer at the time of download look at the one with High number of threads and I/O operations in that interval.
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~ |
#12 (permalink) |
IM AS MAD AS HELL!!
I also get this error
When someone dies in the grip of a powerful rage... a curse is born. Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
