| Forum |
#2 (permalink) |
C# Be Sharp !
well search for :free prixy server" on google . then select a site n open it e.g. proxy4free.com then select a proxy server address n port .
now open internet explorer tools -> internet options->connections , here choose your net connection n set proxy server for it . --------------------------------------------- if my post helped you then there's always the thanks button to click.
There are 10 types of people in the world: those who understand binary and those who do not. |
#4 (permalink) |
champ_rock
ok so what i understand is that you are trying to access some blocked sites by ur college or office computer??
try to go directly to this site..http://www.hidemyass.com/
------------- Registered Linux user number 400618 |
#6 (permalink) |
:-o
Try Anonymizer
www.amiable.in |
#8 (permalink) |
:-o
Well Its not free
BTW you can d/l it from http://www.anonymizer.com/consumer/products/anonymous_surfing
www.amiable.in |
#11 (permalink) |
:-o
Well dude you can try this software http://www.v7soft.net/download.htm
www.amiable.in |
#12 (permalink) |
Posts: n/a
man... i had installed ip hider ... will it work ???
if so how to use it??? @aakash .. man u r trying a lot.. but here my firewall is too smarter .. it has blocked "hide" word also .. i had already mentioned this above ... any other plzzz??? @Ashish ... yes man i had seen jap .. but it is giving me trouble while installing itself.... |
#13 (permalink) |
C# Be Sharp !
well try http://www.anonymouse.org , hope it isn't blocked ( who will block an anonymous mouse !)
#14 (permalink) |
Posts: n/a
@Zeeshan
sorry man.. this link is also blocked here.... i hope only alternate is to hide ip.... can nyone know how to hide ip __________ frends plzzzzzzzzz help me yaaaaaaaaarrrrrrrr Last edited by pokiri; 18-10-2006 at 08:58 AM. Reason: Automerged Doublepost |
#17 (permalink) |
:-o
hey which firewall are you using............
www.amiable.in |
#19 (permalink) |
you can download the file by going through websites like www.magictrainstation.com or www.homemadespacecraft.com...... these sites will hide your ip and you can visit any website you want..... at first it will show navigation error ...but you you hav to click continue to this website..... after that you can download any file of any size....... but these sites dont hav resume support..... better download the file during nite time when the net is speed..........
#20 (permalink) |
NEXT BILL GATES
its pity to see u guys struggling so much......
try them...... anonymouse( .com or .net ..not sure try both of them...one ought 2 work) anonymizer.ru(a russian site place the url in a bar at top and click an adjoining button....sure ur school guys don't know abt them)
KNOWLEDGE IS POWER!! |
#21 (permalink) | |
Wise Old Crow
I found that my entire PC and Connection(IP add, Service provider) info is visible. Is it possible to setup my router for anonymous browsing? __________ Help help!
http://twitter.com/blueshift155 Last edited by blueshift; 10-12-2006 at 10:35 PM. Reason: Automerged Doublepost |
#22 (permalink) |
hey....
use JAP....... its pretty cool and easy to use...i am still using... jus install it and give ur prxy settings to JAP... it will give u 127.0.0.1:4001 jus change ur brower settings to above proxy.... dats all go through the help in that soft.... search the soft or use the link some1 has already mentioned above... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
