Old 09-10-2006, 11:17 AM   #1 (permalink)
Smile i-pod videos related problem-plz help !
Hi folks,
recently got hold of i-pod 30gb. all's fine. but while using i-tunes to convert and upload 40mb mpeg music videos into the i-pod, it does upload fine, but without any audio. Then I tried uploading 3gp videos through i-tunes which also worked with audio,but the video quality became very bad. Then I noticed in another i-pod which was running fine videos with audio that their video file format was m4v about which i dont know anything. so can anyone help me to upload my mpeg music videos in m4v format. I would really appreciate all the help.
thanks,.
lovemeall26
KNOWLEDGE SHARED IS ALWAYS FRUITFUL AS IT CAN BENEFIT YOU TOO ONE DAY. SO HEY GUYS LETS MAKE THIS A GREAT COMMUNITY TO SHARE IDEAS AND STUFF LIKE THAT,
CHEERS,
LOVEMEALL26
lovemeall26 is offline
Old 09-10-2006, 11:35 AM   #2 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default Re: i-pod videos related problem-plz help !
download free ipod video convertor from here: http://www.videora.com/en-us/Convert...d/download.php
its very easy to use
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 11-10-2006, 10:14 AM   #3 (permalink)
Smile Re: i-pod videos related problem-plz help !
Hi buddy,
thanks a million for such a spontanous reply. I really appreciate your kindness. As per your instructions , I went to the link you gave me and also downloaded the converter. However, upon execution of the downloaded file, it started downloading another file from the internet namely - dotntfx.exe file. I immediately doubted this file and stopped it. Please tell me is it safe to download this executable file, I mean I am very wary of viruses, hence am enquiring from you again to remove my doubts. Please help me in solving my oriiginal problem if there is any other way of doint it too. thanks once again
lovemeall26
CHEERS,
LOVEMEALL26
Old 11-10-2006, 11:31 AM   #4 (permalink)
 Macboy
goobimama's Avatar
that could be the .Net framework setup software but I could be wrong.
I'm like a bird... :)
goobimama is offline
Old 11-10-2006, 04:29 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
u can also use ulead video studio 10 .... works good only hasnt worked for 2 out 55 vids for me
http://beingmanan.com
iMav is offline
