View Poll Results: Did you ever had this kind of problem?
Yes 1 50.00%
No 1 50.00%
Voters: 2. You may not vote on this poll
Old 30-09-2006, 04:34 PM   #1 (permalink)
Kiran.dks's Avatar
Default Help me!No rights to System administrator????!!
Hi!
I have a strange problem. I recently restored my Laptop to the factory settings using in-built HP Recovery Console. At that time 'user' was system administrator. Now after restoring, 'Kiran' is the administrator. But I still see 'user' folder in c:\Documents and Settings. I can't access it nor delete it as a system administrator! Right click properties of 'user' shows 0kb. But avast! is scanning the files in the 'user'. The scan shows all the files which I stored before restoring to my factory settings! But no way to access or delete the profile. Please help me out..becoz it has simply eaten my hard disk space...... How can I delete the 'user' profile and its files?
Kiran Kumar R
Kiran.dks is offline
Old 30-09-2006, 04:52 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Help me!No rights to System administrator????!!
I think u hv NTFS partition!
Try this:
1.) Right-click on the folder and select Properties.
2.) In "Security" tab, click on the "Add" button.
3.) Type the username "Kiran", and then click on OK.
4.) Now select the "Kiran" username in the list and select "Full Control" in Allow. At last click on Apply!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-09-2006, 06:19 PM   #3 (permalink)
Kiran.dks's Avatar
Wonderful Vishal! It worked out! Thank you. I performed the steps you mentioned in 'safe mode'. In normal mode the 'security tab' is not visible. Then added 'Kiran' and gave it 'full control'. That didnot solve the problem. Still I could not gain complete access to the 'user' profile. It required taking ownership in the permissions tab. Then its over...complete access to 'user'. I recovered the lost data of 11GB!
Thank you once again Vishal.
Kiran Kumar R
Old 30-09-2006, 10:36 PM   #4 (permalink)
I think you have WinXP home if you can see Security tab in safe mode only... In Win XP Pro, it is available in regular login also.
Arun
sakumar79 is offline
Old 30-09-2006, 11:33 PM   #5 (permalink)
Microsoft MVP
Glad to see it worked for u
