Old 17-09-2006, 12:34 PM   #1 (permalink)
Arrow Video Editing Problem..urgent...
Hello all...
I shot a video from a digital camera but while shooting, I held the camera vertically (At 90 degrees to the normal orientation)...The videos are thus inclined at 90 degrees to the screen while viewing them on the PC..
My query is that is there any technique (read software) which I can use to tilt the entire video clip, so that it can be viewed normally on the PC screen??? I am attaching a screenshot of a frame of the video...Please extend any help if available...
Its kinda urgent...Looking eagerly for replies...
Thanx in advance...
-HK.
h_kunte is offline
Old 17-09-2006, 01:21 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: Video Editing Problem..urgent...
Yeah, its pretty much straight forward. Had it been just flip vertically or horizontally it could have been done on the fly during playback using ffdshow. You can now convert the video using Virtual dub and use the built in rotate filter. Import the file, add the rotate filter, select video and audio compression again - as per your needs and save as AVI.
Just made sure it works, on my system. Here is the screenshot
Sourabh is offline
