Old 16-09-2006, 02:34 PM   #1 (permalink)
From Sri Lanka
thilina's Avatar
Default Bit torrent problem
I have never used bit torrent.I used to download via an ADSL connection (100Mbps shared among 6 PC's via a router or something.).When I download through a download manger the download speeds are gr8.but when i tried via utorrent or Azuereus its damn slow.i dont get any download speed almost all the time.What could be the problem???
thilina is offline
Old 16-09-2006, 02:44 PM   #2 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Arrow Re: Bit torrent problem
open Azureus .. Check for errors if any showing in the system bar in Azureus
2. go to Tools>NAT/Firewall check
3. Make an exception in the firewall for the port
rollcage is offline
Old 16-09-2006, 02:47 PM   #3 (permalink)
From Sri Lanka
thilina's Avatar
Default Re: Bit torrent problem
Is this happent coz of the router??
thilina is offline
Old 16-09-2006, 02:50 PM   #4 (permalink)
rollcage's Avatar
did u tried the above .. and answer to that first, then can tell why is it slow. firwall may be blocking it
rollcage is offline
Old 17-09-2006, 12:27 AM   #5 (permalink)
Talking Re: Bit torrent problem
In the torrent network, there are two types of users: Seeders and leechers.
Seeders are those who either have a part of the file to be downloaded with them or have the full file. Leechers only download, they do not upload because they do not have the file or maybe they are selfish . Whenever you download a file, after you have downloaded some percent of it, you start uploading. Maybe the file you are downloading does not have enough seeders. Check the file info in the site you downloaded the .torrent file from. If it does not have enough seeders, try searching for another copy which has enough seeders.
Dumbledore is offline
Old 17-09-2006, 01:35 AM   #6 (permalink)
rollcage's Avatar
True .. if less seeders that also may be the cause
rollcage is offline
Old 17-09-2006, 02:14 PM   #7 (permalink)
From Sri Lanka
thilina's Avatar
I am using my conn from a cafe.Ill go there on monday.Ill chk wat u told me & inform you
thilina is offline
Old 17-09-2006, 02:20 PM   #8 (permalink)
Bayerische Motoren Werke
Third Eye's Avatar
@thilina: First you know properly about torrents,go for that torrent which has full health and has more seeders.
File not found. Should I fake it? (Y/N)
Third Eye is offline
Old 17-09-2006, 02:23 PM   #9 (permalink)
From Sri Lanka
thilina's Avatar
Wat?
How can i find that kind of a torrent??
thilina is offline
Old 17-09-2006, 03:13 PM   #10 (permalink)
Third Eye's Avatar
The more "greenlevel" colour tells the health is excellent.
