Old 15-09-2006, 09:49 PM   #1 (permalink)
Default Troubleshooting XP installation....
I have a system with 1.7GHZ , P4 , 512 MB + 256 MB SDRAM
I had some problems in XP SP2. The system began to restart sometime after booting . It also showed some Memory Access Error . After this I ran memtest86 .The memtest86 displayed lot of errors in the memory .
I replaced the 256 MB SDRAM with 512MB SDRAM. But still the problem did not stop. I decided to format and reinstall windows. I used many XP cds to do tht, but after the formatting , when the file is copied it shows up "cannot copy filename" . Several files were not copied during the installation and the installation failed.
I dont know wat the problem is. Also i cant understand how 4 cds fail . So i thought there may be problem in the hardware.
Any suggestion to troubleshoot?
rvgopal85 is offline
Old 15-09-2006, 09:58 PM   #2 (permalink)
Anand_RF's Avatar
Default Re: Troubleshooting XP installation....
From the first line that you've typed, it seems to me like you've placed both the 512 mb RAM AND the 256 mb one. Remove the 256 mb one if that's the case, it'll do more bad than good for your pc.
btw what motherboard do u have?
Anand_RF is offline
Old 15-09-2006, 11:03 PM   #3 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Cool Re: Troubleshooting XP installation....
Check the speed (i.e. frequency) of both RAM. If they have different speed then there will b such prob. To use both RAM simultaneously, they shud have same speed.
n2casey is offline
Old 15-09-2006, 11:52 PM   #4 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
typical solution to that prob....ur ram one/both RAM is/are SCREWED.
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 16-09-2006, 01:02 AM   #5 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Problem might also creep in because of CD/DVD ROM too
Check them
techtronic is offline
Old 18-09-2006, 09:31 AM   #6 (permalink)
I originally had 1 256 MB and 1 512 MB , now i sold the 256 MB RAM after the memtest .
Now i have 2 512MB RAM and 1 128 MB RAM.
I have 2 dvd drives. I've tried installing xp from the other drive , still it gives same error. I tried using the cd in my friends computer and the xp installation was done without any errors .
Old 18-09-2006, 09:13 PM   #7 (permalink)
Use only one 512MB Ram and Only one DVD Drive in Secondary Master to installation of XP SP2
I have same problem with TWO CD/DVD Drives in Installation of XP SP2, but Solved it.
Try It.
I don’t know everything, but try to Understand Everything
vrnoormd is offline
Old 18-09-2006, 10:44 PM   #8 (permalink)
::vicky::'s Avatar
try ur friends ram and t that time dont use ur ram both of them
::vicky:: is offline
Old 20-09-2006, 06:14 PM   #9 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
@rvgopal
man u got 3 slots????
Old 23-09-2006, 07:52 PM   #10 (permalink)
Ya i have 3 RAM slots ....
Now iam running with just 2 - 512 MB RAM and reinstalled xp , but still the probelm is not over ...the system gets restarted as it likes randomly
I thought it could be a error in L2 cache of processor .... any thoughts?
__________
I forgot to tell one thing.....
XP did not get installed with the 2- 512 RAM . I removed the 2 - 512 MB RAM , and installed the 128 MB only. This time the xp got installed without any errors ......... i had some problems as i told earlier wen i tried to install xp with the new 512MB RAM
So iam confused....any solution to this prob
__________
I also had a memtest run with the 2 512 MB RAM , and it showed a memory error at 756.4 MB ...... so could the RAM be a prob?
Old 24-09-2006, 02:37 PM   #11 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
dude as i told u ur 512 ram is screwed...get it replaced...it had once happend to my friend..he had to change his ram then....
