I have Installed Winxp With SP2 then vista Transformation Pack.. After Installing Transformatoin Pack Successfully Nothing Has been Changed Except Log off Screen and Soung Theme , Neither Boot Screen Changed nor Theme... Where is the Problem?
Please dont use these transformation packs as they consume too much RAM
Instead use Brico Packs(Search in Google) as they directly integrate with the system 32 folder thereby enhancing the GUI and also consuming only 3 to 5 MB of Precious RAM
