Old 14-12-2004, 09:32 AM   #1 (permalink)
Default MSCONFIG is not running in Win XP ( Start> Run > Msconfig )
im using windows XP prof.. and from last 3 days im not able to run MSCONFIG utility.......
After writing Start> Run > msconfig no result appears ..
What should be da solution i have done full antivirus scan and full spyware scan no result..........
my regdit also not opening
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
imprince is offline
Old 14-12-2004, 10:18 AM   #2 (permalink)
swatkat's Avatar
it may be due to viruses,check if any task named "Netstatt" is running,if it is,then it's a Trojan.Try terminating Netstatt.exe and then run Msconfig.Update ur AV and check for viruses.
the problem may also occur due to W32.Donk virus.then t0ry the solutions posted here:-
http://www.thinkdigit.com/forum/viewtopic.php?t=11079
http://swatrant.blogspot.com/
swatkat is offline
Old 14-12-2004, 10:56 AM   #3 (permalink)
swatkat's Avatar
u posted there in MSConfig.exe not opening thread,so i posted reply there,
check out removal method:-
tell me if it works.
swatkat is offline
Old 14-12-2004, 08:19 PM   #4 (permalink)
sachin_kothari's Avatar
Have you removed IE. IE is required for these services to run properly. If u have removed IE please install it again. It should start working again.
Progress is not made by Hard Workers! But by LAZY people.
Coz they try to find Easier Ways of doing the same thing.
sachin_kothari is offline
