Old 02-09-2006, 11:38 AM   #1 (permalink)
Exclamation HELP!!! How to allow or disable specific rights in Win XP?
Dear Friends,
I don't know how to allow or disable specific rights in Windows XP. I created Administrative Acccount for my younger brother. But now I have to disable his previlage to install new softwares. I don't know how to do it. Please note that I don't want to convert his account to limited user. I just want to disable his right to install new software.
edlin is offline
Old 02-09-2006, 02:55 PM   #2 (permalink)
nishant_nms's Avatar
Default Re: HELP!!! How to allow or disable specific rights in Win XP?
Then better turn his user into limited user
nishant_nms is offline
Old 02-09-2006, 03:00 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open gpedit.msc and goto:
Computer Configuration -> Administrative Templates -> Windows Components -> Windows Installer
User Configuration -> Administrative Templates -> Windows Components -> Windows Installer
Here u'll find some options for ur requirements!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 02-09-2006, 03:08 PM   #4 (permalink)
Console Junkie
aditya.shevade's Avatar
Vishal is right (As usual) I thought that I had an opportunaty to help someone..... He is right.
--- Console Junkie
aditya.shevade is offline
Old 02-09-2006, 10:08 PM   #5 (permalink)
Beware of the innocent
ilugd's Avatar
i guess the query has been solved.
But my query approximates to this and i didn't want to create a new thread
Can we disable a particular user's access to add remove programs applet, users applet and gpedit
Life is too short. Have fun.
ilugd is offline
Old 02-09-2006, 11:39 PM   #6 (permalink)
Console Junkie
Well gpedit is avalable to admins only.
--- Console Junkie
Old 03-09-2006, 12:27 AM   #7 (permalink)
Microsoft MVP
@ilugd
U can set the privileges for Add/Remove programs here:
User Configurations -> Administrative Templates -> Control Panel -> Add or Remove Programs
For allow/disallow any program, like gpedit.msc or ne other, look for "Don't allow specified windows applications here:
User Configurations -> Administrative Templates -> System
Old 04-09-2006, 09:07 AM   #8 (permalink)
Dear Nishant,
You solution is not practical. If I use your method my brother cannot write (burn) his project CDs also. Okay, anyway, Vishal Gupta solved my puzzle.
__________
THANKS A LOT TO ALL WHO RESPONDED TO MY PROBLEM.
edlin
edlin is offline
Old 04-09-2006, 11:12 AM   #9 (permalink)
ilugd's Avatar
yeah, i cant turn that account to limited too. As pagemaker is used by the user and it needs elevated priviledges
ilugd is offline
- by gohan89
