Old 30-08-2006, 02:55 PM   #1 (permalink)
Burning Bright
anantkhaitan's Avatar
Thumbs up Power On UR PC
LifSoft: This application allows you to control your computer from the power-off state and wake it from the sleep mode. Auto Power-on and Shutdown allows you to control your computer start-up at an appointed date or time, even if the system has been closed. Wake it from the sleep mode at a specified time, and open files, play sounds, run programs, close programs, open a Web site, show a message, and make the computer stand by, hibernate, shut down, or reboot at any specified time. This application uses less system resources. Version 2.0 may include unspecified updates, enhancements, or bug fixes.
Highlight: Resume from power-off state - Auto Poweron & Shutdown allows you to control your computer auto start up and work in specified time. It can wake your computer at
specified date/time, even if the system has been closed in hibernation.
Wake up from sleep mode - Auto Poweron & Shutdown allows you to wake up your computer from sleep mode (s3 standby) at specified time.
Task Schedule - Auto Poweron & Shutdown allows you to open files, play sounds , run programs, close programs , open website, show message, standby/hibernate, shutdown/reboot, etc. at any specified time .
Auto Shutdown - There is a feature of Auto Poweron & Shutdown that you may find useful. It allows your computer auto shutdown at specified time.
Features: Auto Poweron & Shutdown is able to allow users to do this all of the following:
Control your computer resume from power-off state (hibernation).
Wake up your computer from sleep mode (standby) .
Run programs, close programs, open files and open URL at any specified time .
Play mp3, wma , wav and flash at any specified time .
Logs on system automatically (win2000/nt/xp/2003) .
Shutdown or reboot , make computer enter sleep mode (standby/hibernation) at any time .
Synchronize your PC's time to atomic clock servers .
More Features:
Easy to use, install and configure the software in 2-10 minutes.
Support Windows 98/ME/2000/XP/2003.
http://www.lifsoft.com/
http://www.download.com/3000-2084_4-10316201.html
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 30-08-2006, 09:58 PM   #2 (permalink)
deepgeek2's Avatar
Default Re: Power On UR PC
Wrong Section
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
- by gohan89
