Old 30-08-2006, 10:26 AM   #1 (permalink)
Default virus problem
i got a new virus named plasama .it first makes folders in evert folder and it dosent get deleated .it infected every exe file and my nottons deleated all exe file .even if i wrieye a cd some how the virus get into that cd also and it also infected my few friends ...what to do????
plz help
q4_abhi is offline
Old 30-08-2006, 10:58 AM   #2 (permalink)
k_blues24's Avatar
Lightbulb Re: virus problem
Which Anti-Virus solution do u have?
Try each & every AV & run them non safe mode may this will help u.
other-wise u have to format This one drive. Pls do not keep anything in ur sys drive ( where ur sys & other program files r installed ).
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
Old 30-08-2006, 03:53 PM   #3 (permalink)
Default Re: virus problem
Run A Online Scann At Bitdefender.com
If That Not Worked Try To Download Bitdefender And Update It
Then Scann All The System
If You Cannot Install An Antivirus If The Virus Blocks It
Install Kapersky Antivirus On Any Of Your Friends Pc And Then Create
Bootable Anti-virus Cd Throgh It Then Scann All The System
By Selecting Cd As First Boot Option In Bios.
You Can Also Try Avast
Good Luck
gvrappu is offline
Old 30-08-2006, 06:49 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
please confirm if u have spelt ur virus name correctly.
meanwhile run ur norton in SAFE MODE and see if it helps.
clear ur pc junk with 'ccleaner'
post ur hijackthis logfile here.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-08-2006, 07:23 PM   #5 (permalink)
Tux Fan
shaunak's Avatar
get a good antivirus like avast! downloaded on an uninfected PC transfer it to a cd and then install in safe mode. scan. post back.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 30-08-2006, 07:51 PM   #6 (permalink)
Beware of the innocent
ilugd's Avatar
best option would be to try to get access to a clean system. Backup all files first. Then attach the infected harddisc to the sys. boot in safe mode and scan with av.
(Just wondering, if you attach a new harddisc and the first boot is in safe mode, will the hdd be detected? I am betting that it will be.)
Life is too short. Have fun.
ilugd is offline
Old 30-08-2006, 08:12 PM   #7 (permalink)
Livin' in the ghetto
AshishSharma's Avatar
U can boot the machine into Dos and run the Dos scan like McAfee Dos Scan ...
Download the latest Superdat from here:
http://download.mcafee.com/us/update...Dat.asp?real=0
Extract it to a folder and then follow the instructions from here :
http://72.14.235.104/search?q=cache:...n&ct=clnk&cd=1
(Can't find them on any current link)
Worked for me the last time I had virus infection on my machine.
~.~ Never argue with idiots, they just drag you down to their level then beat you with experience. ~.~
AshishSharma is offline
Old 30-08-2006, 09:30 PM   #8 (permalink)
william's Avatar
same thing try use any other antivirus if you can try to deleteit, run scandisk. Do all this in safe mode and also if you can formay your hard drive and try out that also.
The secret of creativity is knowing how to hide your sources.
Albert Einstein
william is offline
- by gohan89
