Old 29-08-2006, 06:06 PM   #1 (permalink)
Default help wid JS urgently
Okay, here goes. I got the script below from the internet. It creates a slideshow with clickable images. Each image in the slideshow can be the link to a unique URL. Problem is, when I click on an image, the target URL opens in a new window, which I don't want.
Is there anyway to tweak it?
<!--Hide from old browsers
var slideimages=new Array()
var slidelinks=new Array()
function slideshowimages(){
for (i=0;i<slideshowimages.arguments.length;i++){
slideimages[i]=new Image()
slideimages[i].src=slideshowimages.arguments[i]
function slideshowlinks(){
for (i=0;i<slideshowlinks>
//configure the paths of the images, plus corresponding target links
slideshowimages("photo01.jpg","photo02.jpg","photo 03.jpg","photo04.jpg","photo05.jpg")
slideshowlinks("blooming.jpg","http://food.epicurious.com/run/recipe/view?id=10092","http://food.epicurious.com/run/recipe/view?id=100975","http://food.epicurious.com/run/recipe/view?id=2876","http://food.epicurious.com/run/recipe/view?id=20010")
//configure the speed of the slideshow, in miliseconds
var slideshowspeed=2500
var whichlink=0
var whichimage=0
function slideit(){
if (!document.images)
return
document.images.slide.src=slideimages[whichimage].src
whichlink=whichimage
if (whichimage<slideimages>
__________
someone plzzzzzz reply.........its very urgent.
noobie4q is offline
Old 29-08-2006, 06:26 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: help wid JS urgently
i dunno much but u can try this....
var slideimages=Array()
var slidelinks=Array()
var whichlink=0
var whichimage=0
function slideit(){
return
__________
__________
and m not sure it ll work... but u can try it...
Pathik is offline
Old 30-08-2006, 02:21 PM   #3 (permalink)
it did not work..............some plz look into this..........
__________
doesnt anyone know Java script???
noobie4q is offline
Old 31-08-2006, 09:24 PM   #4 (permalink)
areey KOI TO BOLO.
someone plz helpme solve this prob.
noobie4q is offline
Old 31-08-2006, 10:33 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
please use the code bbcodes and give entire script
http://beingmanan.com
iMav is offline
Old 31-08-2006, 10:41 PM   #6 (permalink)
That was the full script. I saved it as an external script file.
In the HTML file, I just added the following coding:
<a><img></a>
<script></script>
noobie4q is offline
- by gohan89
